Question about Dryers
LG TROMM Gas Dryer has intermittent rattle noise while turning
I have a LG TROMM Gas Dryer that was installed just over a year ago. Recently it has begun making an intermittent metallic rattle inside the unit (like a loose screw) while the drum is turning. No errors on the display, and it makes the noise whether on timed or sensing dry setting. But it doesn't seem to make the noise if there are no clothes in the dryer, as if weight has something to do with the noise. The unit is stacked on top of the washer.
Is there a way to open the unit to look inside, or any idea of what may be causing the noise?
  • Anonymous Mar 17, 2014
    My LG Tromm DLE7177RM dryer makes a humming noise and the drum will not start when starting the dryer.
  • 547 Answers
Change the drum rollers
Posted on Feb 18, 2009
Loud banding noise in my LG Tromm DLE7177
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 11, 2013 | LG Tromm Electric Dryer
My 10 year old electric dryer (Whirlpool Gold Ultimate Care II) is making a squealing, rattling noise. It still heats up, but something sounds loose. I wondering if I should get it fix or replace it.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 19, 2011 | LG DLG2524 Gas Dryer
Our two year old Maytag gas dryer is making a rattling noise. The noise is intermittent. Also, when the dryer turns off and the drum stops turning something else seems to "run on."
this is most likely a broken wheel which is a wheel that the bearings have worn out on.If it is a wheel you should replace the set because if you replace just the one the others will wear out faster than they should.
Ps if it is only two years old it may still be under warranty!
Oct 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My LG tromm dryer wont heat and i don't know how ignite the pilot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryer is making a rattling noise when in operation. Dryer is eight years old of so. Never heard this noise before.
Rattling could be anything from a bad idler or support pulley or coins in the vanes. If you can hear it you can find it pretty easily.
Eric
Jun 13, 2010 | LG DLE2532W Electric Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Lg tromm dryer making a thumping noise when running. What could this cost me to do myself or pay specialist to fix?
heatman101
ssgf
Feb 07, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
3 yr old LG TROMM DLE 5977W Dryer-loud rattling noise started about a month ago.If I press on the front of the dryer below the door it stops.Something has come loose that stopped the vibrating noise?How do...
Remove the bracket at the top rear of the dryer 6 screws
Tilt top up and forward to remove
Remove operator panel by unplugging connectors and removing screws.
Pull up and forward to remove front panel
Nov 06, 2009 | Dishwashers
Dryers Logo
1,006 people viewed this question
Top Dryers Experts
