Question about Toshiba Estudio 200L Copier
Toshiba 281C Bypass tray
Trying to use Bypass tray on Toshiba 281C. Using Word 2007 on XP machine, printer is networked. I set Printer properties to Bypass Tray and Word's Print Options to Bypass Tray, but it still picks up paper from main tray. What's up??
It worked one time today but not a second time. Anything that needs to be "reset" on the printer that could be forcing to use main paper tray?
  • Anonymous Mar 18, 2014
    how do i clear it when turning machine off doesnt clear the message
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
Posted on Feb 18, 2009
Printer is only printing to the bypass tray instead of tray 1 where it should be printing
First, check your printer properties and make sure you are not telling it to go to the bypass tray.
If you are set to auto tray and its still trying to pull out off bypass tray. Check on the copier to make sure tray 1 isn't set for a special type of paper. If it is, change it to plain paper.
Sep 30, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
HOW do I get my printer to stop trying to print from the bypass tray?
check the printer properties in Windows Control panel and see if printer settings are set to bypass tray
Sep 19, 2014 | Xerox Office Equipment & Supplies
Cant print in color with e studio 281c I can copy in color
The 281c can be set to print to black only as a cost saving measure. The printer control panel is accessed through your browser (using the IP address of the printer) and the setting is made there. You should be able to override this through the printer properties in windows, but I have found that the PCL5 driver worked to switch between B/W and colour, while the PCL6 driver did not. So, for me the easy solution was to install the PCL5 driver and use that.
Apr 02, 2014 | Toshiba E-studio 281c Copier
Windows driver
my Toshiba studio 281c printer operates normally while running on windows xp through my LAN. When I try to print on it while running on windows 7, it will not respond, it does appear in the printer list?
Nov 08, 2013 | Toshiba E-studio 281c Copier
Print envelopes
Under printer properties, u can set the paper size, choose bypass tray.
Jun 22, 2012 | Toshiba E-Studio 2040c Copier
No matching paper size set paper on bypass tray
Someone has told the machine to either make a copy or print from a PC to the Bypass feed tray on the copier. If you are not trying to print something by using the bypass tray then just turn the machine off, then on again to clear the request from the copier. If you are trying to print or copy from the bypass tray then simply insert the correct paper size and direction into the bypass tray slot and the machine should automatically begin printing.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Konica Minolta DiALTA Di200 Copier
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
-Carl
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
E Studio163 - Printing - "No cassette with paper of size requested is available"
after changed one of the sensors ,the same problem-"no cassette with paper of the sieze requested is available" has happened,alway paper jam.
any ideas why?
machine:e studio0259
Aug 27, 2007 | Toshiba e-Studio163 Copier
1,225 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
