The most common reason is either a dirty or bad Optical Pickup unit in the player which is what reads the disc, and you will get no disc, cannot read disc etc.
Be careful to do this with AC cable disconnected from AC outlet! If you have some experience with electronics, disconnect the wired plugs from power supply and discharge electrolitic capacitors to ground with a 330 ohm 1 watt resistor. Then reconnect the wired plugs. Be careful to do this with AC cable disconnected from AC outlet! Then connect to AC outlet and turn on the DVD player. You will see that DVD player restores to normal operation again.
[email protected]
i JUST tried the unlock to multi region for my samsung ht-tz315 and it didn't work does anyone have a crack for this please. thks
the code was
Turn On player with remote Press Enter on the remote Press 8, 4, 2, 6 and 9 on the remote Press Enter on the remote The player will power Off Switch On power from remote
