Question about Compaq (261671-001) Motherboard
I unplug my hard drive and now I cant get my computer to start up
There 3 lites on the back onf my dell A B C and D The D lite is on and is orgern not green The moniter all so says that that it on power save mode and thats all it will do when i turn it on
  • 285 Answers
Try switching your power cable with te one from another pc, if that doesnt help check wether the on/off button on your power supply is turned on. If that doesnt help either I'll need more info about what those lights indicate.
Posted on Feb 18, 2009
2001 pt,abs &trac lite come on car hesitates sometimes dies,in a garage & they cant find the problem
I have a 01 pt that did the same thing. By you're exhaust manifold there is a thick wire set with loom over it. Pull it back and check the orange wire. It controls the crankshaft Senor mine was burnt through. Easy fix black tape and a price of wire, spliced it together and was good to go. But I relocated the wire off my exhaust
Jul 17, 2012 | 2001 Chrysler PT Cruiser
Fix a HP DV5200 that will not boot
faulty CPU most likely. take the CPU out and get a replacement from EBAY etc. get some isoproyl alcohol and some thermal paste from there too. warning: you will need to reformat your hard drive as the BIOS settings will most certainly be different and you will probably get the BSOD (blue screen of death) by trying to cold reboot from the same hard drive. back everything up first. take the hard drive out and get a caddy and backup to another machine.
Mar 07, 2012 | Pavilion DV5000 DV5100 DV5200 Series...
Dell c521 motherboard diagrams problems
Per Dell's support site: If the power light is a solid amber, a device might be malfunctioning or incorrectly installed.
Turn off the computer and unplug from power:
I would remove and unplug everything except the memory and video card. Then plug the computer back in.
If it posts (dell screen and then a hard drive warning), turn off the computer and start reinstalling each component one at a time and turn on between each install. Hopefully one compenent will fail and you will know what is bad and needs replacing.
If the computer still had the amber light, remove one of the memory modules (hoping you have 2) and try again. If it still fail exchange the modules. If this works you have a bad memory chip, reinstall the rest the componets to double check and power on. Replace the bad chip.
If the computer still fails on both modules, remove both, you should now get a memory beep code, if not then the video card is most likely bad and will need to be replace.
Hope this helps
Jan 31, 2012 | Dell Dimension C521 PC Desktop
Shut down my PC, unplugged it, moved it to new location. Plugged it back in and it would not power up green light on the ASUS P4P800SE would not stay lite. Replaced power supply, green light on the mother...
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
Jan 11, 2011 | ASUS P4P800SE Motherboard
I mite have deleted my lite-on combo sohc 5232k by mistake can you help to get it back plz
control panel administrive tools computer management device manager scroll to cd/dvd drives you should see either a red x or a yellow ! or a? right click to install drivers or
open up your computers side panel to access the lite combo drive unplug it then plug it in again from the electical lead
this should activate the found new hardware wizard then you might have to install the drivers for this device
hope this helps
Dec 09, 2010 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Dell 8200 green power lite comes on green hard drive lite off
Check your fans o see if they are running and if the PC isn't getting too hot because that will cause it to stop and not boot up.
Dec 29, 2009 | Dell Dimension 8200 PC Desktop
Pc can't detect harddrive
Try this, take and unplug the drive from the computer and do a reboot of the computer. Then once your computer is back up, try plugging in the drive again and that should take care of it. If it does not, Go to the Start Menu, then Control Panel, then System. Click on the Hardware Tab and then click on the Device manager button. In the right side of the screen you should see a little yellow icon on the drive in question. Right click on the device and select uninstall. Then reboot your again and plug in the drive.
May 30, 2009 | SmartDisk 40GB - 4200rpm - 40MBps - IEEE...
I have a Dell Dimension 4550 running windows XP Home. I just recently purchased a new DVD drive(Sony Optiarc AD-7221A) and I can't get it to work. The first drive I tried was a Lite-on DVD burner, and now...
sounds like you have issues with your hard drive.  go to start>run.
type this in without the " "
"cmd", hit ok.  a black screen pops up.  type "cd.." and hit enter.  type in "cd.." and hit enter again.  type "chkdsk c: /f /r".  It will say the drive can not be checked, it is in use.  hit "y" to schedule a check at boot up.  type"exit" and reboot your computer.  let me know if this helps.
Mar 07, 2009 | Dell Dimension 4550 PC Desktop
My new Sony Optiarc AD-7221A DVD drive won't work
for your old sony drive that wont open...
look fort a small hole, like a little bigger than a pinhole, in the front panel of the drive. if you can find this hole, stick a straightened-out paperclip or something similar in the hole, and gently force it in, and this should open the cd drive.
a page file error has to do with ram saving to and reading from the hard drive, using a portion of the hard drive as back-up virtual ram. perhaps there is a bad sector on the hard drive, or some other sort of error with either the hard drive or ram to cause the "page file error" and the inability to play dvd's.
if you can get that old drive to work, that may be your best bet.
Mar 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Lite-on sohc-5232k problem
Try system recovery if it is turned on, also you may try to unplug and plug back your drive from motherboard.
Good luck
Jan 31, 2008 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Compaq (261671-001) Motherboard Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
