Question about Gateway 420GR PC Desktop
Jumbled video on startup removed 6 malware and restarted the system ,bios settings came up , i exited (saved settings )and video was in multiple blue squares and unledgible.System will not go into windows now
    Problem Solver:
  • 7 Answers
Before windows starts to boot press F8 as if you were trying to start safe mode and select the option about enabling vga something and restore your video card drivers
Posted on Feb 17, 2009
Boot from cd
Usually when you get messages like this, this often it is malware. I assume your real problem is cleaning your system of this malware, not booting to a CD. Your best bet is to restore to a system restore point before this started happening. Google around for how to do that in your operating system. If you don't have a working system restore or that doesn't resolve your problem please follow this malware removal guide to the letter: http://forums.majorgeeks.com/showthread.php?t=35407
WRT your question about the boot disk:
A bootable optical disk is an ok approach but it is not a simple process. You will probably want to create this disk on another computer. The disk must be bootable (an instruction is written to the first part of the disk which is interpreted by your bios as bootable media). If your recovery program is a file that ends with .img or .iso then it is an optical disk image which is compressed. I'm assuming you have windows 7 based on the model of your laptop. If so you should be able to double-click the image file and it will open Windows Disk Image Burner where you select the burner drive letter and click the burn button. Once you've done all of that you may need
enter the bios to change the boot order. In the bios you should see a tabbed menu screen that has these headings:
Main ' Config ' Date/Time ' Security ' Startup ' Restart
The boot order is in the Startup menu. You'll want your optical drive (CD, DVD, or Blu Ray) as the top item in the boot order. Save and exit will save these settings and restart your computer. It should now boot the CD.
Mar 25, 2014 | Lenovo ThinkPad X200 Tablet Laptop
Compaq Presario pops up a system boot menu everytime at startup.
This comes up mostly when it requires a BIOS save. Try that. If that does not help, sometimes setting the default settings and saving will help.
Dec 04, 2012 | Computers & Internet
Doesn't enable virtualization
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
Aug 08, 2012 | Computers & Internet
I upgraded my bios and my machine loads to a windows logo then goes to blues screen for about a second then resets is there a way to restore the bios to factory default
You need to download a previous version of the BIOS and try to update the PC with that.
Before you do, go into the bios settings and use the 'set bios defaults' option to see if you can clear the bios to a better state. You can also remove the CMOS backup battery on the motherboard, leave it for a few minutes and put the battery back. Then restart the PC, go into bios setup, Save & Exit the bios and see if it boots up. Also, try starting Windows in Safe mode (press F8 during the boot up process to get the windows startup menu).
Mar 09, 2011 | Computers & Internet
How to set my acer laptop to factory settings
Reinstall Windows is the only way to take it back to previous state.
Feb 28, 2011 | Acer (ACERMOTHERBOARD)
Keeps shutting down.
To resolve the issue, Please perform the following steps:
Step 1: BIOS Reset
To reset the BIOS defaults, follow these steps:
1. Restart the computer and press F2 (F10 in some Notebooks) as soon as the HP logo appears.
2. Go to Exit menu and select Load BIOS defaults or press F9.
3. Go to Exit menu and select Save changes and Exit or press F10.
This will reset the BIOS defaults. Now, when the Notebook restarts, press F8 repeatedly until the start up menu appears. Select the Safe Mode and press Enter Key to enter in Safe Mode and then perform the step 2.
Step 2 : Disable the "Automatically Restart" under System Failure:
1. Click Start, right-click the My Computer icon, then Properties.
2. Click the Advanced tab, then Settings in the Startup & Recovery section.
3. Remove the check mark next to Automatically Restart under System Failure.
4. Click OK to close the Startup and Recovery window, then click OK to close the System Properties window.
5. Restart the computer.
Step3: Reinstall Power management
To reinstall Power Management in Windows XP, follow these steps:
1. Click Start, select Control Panel, and then choose Performance and Maintenance.
2. Click the System icon to open the System properties window.
3. Select the Hardware tab and click Device Manager.
4. Click the plus (+) sign next to System Devices.
5. Right-click the ACPI Fixed Features button and select Uninstall.
6. Restart the system.
On restarting the system, Windows will automatically detect and install Power Management on the computer.
May 25, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Black screen after windows xp startup screen
Hi Topdarr,
How are you?
I have read your posted problem and would like to give you few suggestions.
1. Start your PC and start pressing F2, F10, DELETE or the The Key assigned for your PC BIOS, you can find that on your PC Screen.
2. Once you enter in the BIOS press F9 to make your BIOS to it's default settings.
Alternatively you can navigate to Exit menu and move UP and Down With Arrow keys and select load default settings.
3. Now press F10 key to save your settings or select Save Settings & Exit .
Your PC will reboot after exit.
4. Please reboot your computer in Safe Mode by doing the following:
To go into safe mode -- Press F8 key as soon as the pc restarts.
(You will have do it again if pc starts in normal mode.)
On the black screen >>> LAST GOOD KNOWN CONFIGURATION.
Press enter Key Twice to boot your PC.
Please let me know the result.
Thanks
Techgems
Sep 19, 2008 | Computers & Internet
Toshiba Satellite M45-S169 won't boot
you must restore your bios settings to the correct ones. contact toshiba customer support for the correct toshiba settings.
Jul 27, 2008 | Toshiba Satellite M45-S169 Notebook
Compaq evo n1050v laptop rebooting on XP startup
When you start it hit the f8 key,highlight safemode without networking.If it boots do a system restore.
Feb 28, 2008 | Computers & Internet
Acer 3089
hmm which password ??? is it the bios password or the windows password.. Any way I will give you solutions for both
THE BIOS PASSWORD
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
TO RESET WINDOWS PASSWORD
1.) dowload hirens boot cd from here
www.phazeddl.com
you will need to search hirens when you go to the site
2.)burn off cd
3.) boot from cd
4.) use the on screen menu to fine windows password reset tools,
5.) choose the appiorate one and follow instructions to change or reset password..
THATS IT WINDOWS PASSWORD RESET..
let me know if you need any more help good luck
Jan 10, 2008 | Acer Aspire L100 PC Desktop
Gateway 420GR PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
