Question about MSI Wireless-G RG54G3 Router
Hey there. I have an msi router model: NO:RG606 For some reason only me, being the main user of the router can connect to the internet. My other buddy in my house cannot connect although there is good signal. Also my playstation 3 has wireless connection and for some reason i have 100% signal but i cannot connect to it. Please let me know how i can fix this because i have tried buying a new router and the same problem exists. thank you
    Master:
    Sergeant:
  • 226 Answers
Login to the router interface make sure there is not a block for anyone else to use it and the playstation you have to enter the wep code or whichever the encryption you used
Posted on Jul 20, 2009
Windows installer vista
Reset the router and on some models you can do this with a pin hole in the back or bottom. Also to change the settings on the router, you have to be connected by wire, you cannot use wireless.
Feb 09, 2014 | D-Link Computers & Internet
Can connect to my laptop wirelessly but internet (router msi rg60
There may be two reason here.
1. If there is any securities like Norton, Macafee, web root which is stopping it again and again. Please unintall these securities once and reinstall them again.
2. Else, it may be an issue with Router. You can disable the security of the router once and check it. or you can reset your router once.
3.Also, scan your computer with malwarebytes. http://www.malwarebytes.org/
Mar 23, 2010 | MSI Wireless-G RG54G3 Router
My computer shows "local" connection only - why is that?
could be a number of reasons 1) The router has not been setup correctly - log back into the router and check all the details User manual here http://www.msi.com/index.php?func=downloadfile&dno=5098&type=guide
2) Login to the router and see the status page and if that is showing connected also look at the lights on the front of the router and see if connected WAN Light make sure the cable from the modem is connected to the WAN port and the lights on the modem are correct
3) On the PC make sure that the firewall is not blocking access disable any firewall
if this does not solve the issue post back the following
[b]{ipconfig /all}[/b] If you cannot access the internet with this PC, then you will need to paste the results into something like notepad and then copy onto a machine that can access the internet and post results here We would like to see the results from ipconfig /all post back the results here -> Start -> [i](XP - enter the following in the RUN box)[/i] [b][color=blue]cmd /k ipconfig /all[/b][/color] -> [i](Vista or Windows 7 - enter the following in the Search box)[/i] [b][color=blue]cmd /k ipconfig /all[/b][/color]
A black box will appear on the screen - rightclick in the box select all enter control key + C key - to copy
then reply here and control key + V to paste [b]------------------------------------------------------------------------[/b]
Mar 18, 2010 | MSI RG54GS Wireless Router
Is there a way to reset a user and password that is lost
Simply get a paper clip / straighten it and insert / hold in rear if DSL model till all the lights go out and blink. Rest complete.
Be aware it will delete all saved passwords and reset to manufacturers default.
If you do not know what your internet user name / password are then you will have to contact your ISP to re-issue new password.
Mar 10, 2010 | MSI Wireless-G RG54G3 Router
Need instal software for msi rg54gs wireless router?
is the router brand-new? If not, trying re-setting it using the recessed reset button at the back....it is possible that a previous configuration of the router might have changed it's local IP address.
Apr 21, 2009 | MSI RG54GS Wireless Router
Hey, i'm having trouble setting my MSI wireless router
Make sure the physical connection is correct.
- Cable/DSL Modem > connected to Internet Port of the router.
- Computer connected to port 1 on the router
First, try to reset the router. Press the reset button at the back of the router for 20 seconds, then unplug the power to the router and the modem. Wait for 30 seconds, power on modem first, wait for the lights to go solid, then power on router.
That should be all set. If not, please run the Setup CD that came with your router.
Dec 03, 2008 | MSI (MS6848) Wireless Router
Help?
Something internally died. if you are willing to start replacing chips inside the thing. let me know the part numbers from the chips.
If you dont want to get into surface mount soldering I would suggest canning the thing or EBAYing it as parts.
Apr 30, 2008 | MSI Wireless-G RG54G3 Router
Help me please
Two separate solutions are needed.
First, you will need to ask your ISP (Internet Service Provider) to assign a "fixed IP address" to your Internet connection. Your ISP typically assigns addresses to home users out of a large "pool" of addresses that are shared among several customers. Because of this, your home network address is not always the same. Most ISP's charge an extra fee to always keep your address the same.
The second task is to configure the firewall function in your router so it will pass connections through from the WAN to the device inside your network. The procedure to do this should be included in the instruction manual for your router.
Jan 06, 2008 | MSI Wireless-G RG54G3 Router
MSI RG54G3 router cannot connect to internet
i hink this issue has been resolved by you by now. if it perists do lemme know about it. it seems yor router is not configured properly regarding the authentication like user name n password. n i think the MAC address spoofing is also into the picture , mostly MAC add spoofing is done on cable connections but sometimes it can be also used with the "user id n password" together. For any other issue- chat with me on msn or yahoo messenger my id is samrat101 on both the messngers samrat
Aug 12, 2006 | MSI Wireless-G RG54G3 Router
MSI Wireless-G RG54G3 Router Logo
156 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
