Question about Dryers
The dryer has electricity to it but won't come on.....it beeps as if the door isn't closed, but it is...
  • 547 Answers
Change the switch for door
Posted on Feb 18, 2009
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Jun 21, 2014 | Kenmore 659 Electric Dryer
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
Whirpool Fronload Dryer has power, timer cycles through, but it is not running. The dryer worked two days ago when I ran a load. I went to dry a load this morning and it turns on, everything lights up...
The reasons can be a fault on the program controller unit but as the door does not close the program also will not move further. This must be the clue to the fault. Remove and check the lock and the settings. manually close the door with force and see if the program cycle starts, if not check the door switch and the control panel. Also check for output when the timer counts down. If not the controller unit must be checked for possible problems.
Nov 14, 2011 | Whirlpool GEW9250 Electric Dryer
Replaced igniter and valve assembly still won't fire up?
check the door locking mechanism, if the door isn't giving a signal that the door is closed it won't fire up,
Jul 21, 2011 | LG D2526 Gas Dryer
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Can not close the door
how do you mean it won't close?it doesn't latch or are the hindges damaged and the door isn't closing tightly
Apr 16, 2011 | Whirlpool RBS305PDS Electric Single Oven
Dripping out water from dryer and takes 2 or more cycles to dry clothes. Seems like door isn"t sealed with closing all the way, dryer 15 months old.
Is your dryer vent clean? I would check to make sure vent is cleaned.
sounds like its not exhausting properly
Oct 21, 2009 | LG DLE0442 Electric Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
