Question about GE Spacemaker JVM1640SJ Microwave Oven
The power when off
Mo power or light at all
  • Anonymous Feb 22, 2009
    The whole unit just died suddenly. No power, no function, no nothing.
  • Anonymous Apr 02, 2009
    GE Spacemaker 2.0; no power at all and wall plug is working
  • 52 Answers
Presuming you have checked the plug fuse.
remove the casing of the unit, and check the internal fuses. I am sure this will sort your problem
Posted on Feb 21, 2009
I found e_21 in Samsung combi microwave oven after we power on the button
I would try resetting it first. Unplug MO, wait about a half hour, plug back in.
Oct 01, 2017 | Samsung Microwave Ovens
Blower fan run when i shut the door and never shuts off what could the problem be mo#rcs10ts
Some brands of microwaves will do that when you have a bad door switch or the door/switches are out of adjustment. In most cases the actual microwave isn't running just the light and fans but it does need corrected.
Mar 31, 2015 | Amana Microwave Ovens
My Jack Hammer JH600 1200 Watts Amp will not turn on what could be the problem?
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some mo
May 22, 2013 | Microwave Ovens
My Jack Hammer JH600 will not turn on what could be wrong?
5. Clock needs to be set before other functions will operate (some mob13fba98-cfd6-48cc-90f8-20b4ee6eed63.gif
My dcs mo-24-Ss microwave oven cannot heat the food after turn on, everything working fine other than no microwave come out
Assuming the turntable, inside light, and internal cooling fan all work when you press "Start" to cook, then I would suspect a bad magnetron, or a bad connection at the "FA" terminal of the magnetron.
If one or more of those three items do not work when you hit "Start", the I would suspect a bad door switch or mount.
The DCS MO24SS is essentially a rebranded Sharp R-530E-series microwave with different cosmetics and a higher price.
The service manual for the Sharp model is here.
The internal Sharp parts in the manual will interchange, but not the external cosmetic parts.
You can order Sharp parts from Encompass here.
Nov 22, 2012 | DCS MO-24-SS Microwave Oven
I need a new waveguide cover.
Just go to your machanic or the nearest waveguide selling shops
Feb 26, 2011 | DCS MO-24-SS Microwave Oven
Flash in oven
The flash is usually caused by metal either being placed inside of micro or the interior surface might have chipped enamel exposing the metal underneath. Make sure no metal materials are placed inside while using and that the interior surface is in good condition.
Dec 08, 2009 | DCS MO-24-SS Microwave Oven
I have a DCS Model MO-24SS. The other day I was
Main fuse is under outer cover Its a large ceramic fuse and costs about $30
Jul 25, 2009 | DCS MO-24-SS Microwave Oven
Information about microwave leakage
Hi, you seem very concerned with your Microwave Oven "Leaking" & I would like to set your mind at rest. Now whilst all this is possible, in actuality it is a rare event. The manufacturers must meet very Strict & Stringent regulations regarding "Shielding" and "Protection" There are many safeguards inbuilt into the MO. Also the ONLY time that anything is "Emitted" is when the MO is actually being used. The Microwave Oven (MO) is for all intents & purposes is a "Radio Transmitter". Inside the MO, there is a device called a Magnetron, this device converts your mains Power into High Frequency Radio Waves, in the 2.5GHz Spectrum. These radio waves are exactly the same in makeup as ALL other Radio waves that are all around us all the time, and cause us no problems. You are prudent to be concerned but please rest assured the "Risk" from any "Leak" is extremely low.. even if it did "leak" in the first place. To answer your questions in turn... 1. No they do not... 2. No they do not. 3. Yes one can purchase a simple Microwave Oven "Leak Detector". Generally the only place that one may get a "Leak" from is around the "Door" seal.
Sep 09, 2007 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
88 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
