Question about LG LB1200ER Air Conditioner
Installing a sump heater or cold weather use.
Part#5300ar2915a a sump heater on a2 ton ductless split system 220 volt supply.where do I make the electrical connections for this heater?
  • 121 Answers
Air conditioner can work at 0 deg C outside temp and you do not need a heater for compressor if is split system.
Posted on Feb 17, 2009
What type and size condensor fan goes in a 2 ton split system?
depends on the manufacturer. go to manufacturer internet site with model and serial numbers for parts info. if you are talking about a system other than rheem,trane,lennox. it is usually in the 1050 rpm, 220 volt,1/3 hp and you could use a rescue motor to replace it with. reversible motor.
Oct 11, 2015 | Heating & Cooling
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Teledyne Laars LLD400NB natural Gas
if wired 120 volt change fenwal from 220 volt to 120 volt if it takes like 3 times to lite
Feb 05, 2013 | Teledyne Laars Pool & Spa
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Do i use 10-3 withground?Im hooking a 18000 BtU Ac heater
A normal 2phase 220 or 240 V unit usually requires
2 wires and a ground. If you know what a contactor
is you will notice that only two line voltage wires can
be inserted into it and the ground wire to the equipment ground.
If you have a 3phase unit you would need 3 wires and a ground. Usually on the back cover of the unit it will
show the wiring diagram
Jan 12, 2010 | GE Quiet-Aire Ductless Split System Air...
I am concerned the wiring diagram provided for a Ramsond 12000 btu split system 240 volt is wrong. (1 2 3 N L L N) I assumed the L's were slots for the hot legs.
Those terminals on a ductless split are reserved for the communication wires from the out door to indoor unit. L L N should be line 1, line 2, and neutral (ground) there should be a 1 2 3 N terminal block in the indoor unit also, those terminals would most likely be for the communication between the two units.
May 17, 2009 | GE Quiet-Aire Ductless Split System Air...
Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
May 01, 2009 | Carrier 36KCARMS Air Conditioner
LG LB1200ER Air Conditioner Logo
99 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
