Question about Lexmark Office Equipment & Supplies
Lexmark 2690 where is catridge - Lexmark Office Equipment & Supplies
  • Lexmark Master
  • 19,396 Answers
It is underneath the scanner, you will need to pull up the scanner part of the printer.
Follow instructions below:
How to replace a lexmark AIO print cartridge
How to Insert Color Cartridges in Lexmark Printer Scanner
Replacing the print cartridge
Posted on Feb 17, 2009
Lexmark x3480 catridge incorrect
It could be faulty cartridge issue. Try to replace a new genuine cartridge to determine if the other is faulty.
Mar 16, 2012 | Lexmark X3480 All-In-One Printer
Hi I bought a lexmark S405 and when my ink finished, i decided to refill the black catridge but the print wont print unless i buy a new catridge which is expensive than buying a new printer. I wanna...
The Lexmark S405 printer requires all cartridges to have ink in them to continue printing.
The 100/100XL cartridges are not licensed to be refilled. You can, however, refill the 100A or 100XLA cartridges available on the Lexmark website at http://www.lexmark.com. You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
Sep 20, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My lexmark 7170 printer has error message : right cartridge incorrect. I pulled the brick. Waited a few minutes, replaced but error still appears. Turned off and on etc. Lexmark quide was not helpful. any...
You are trying to put the wrong catridge into right hand side,. the catridge you have put is incorrect. try removing the catridge and put the right catridge back
Jan 09, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Nov 29, 2009 | Lexmark X6570 InkJet Printer
Cartridge lexmark 15 is compatible with lexmark x2690?
No, a Lexmark # 15 is not compatible with the 2690.
The 2690 uses a #4 (Black) or #5 (Color). Also a # 4A (Black) and a #5A (Color). You can also use a #31 (Photo Print) cartridge.
Don
Jul 02, 2009 | Lexmark X2690 All-In-One InkJet Printer
Lexmark 2690 has encountered a printer card transfere problem and needs to close
Huh? I went to the Lexmark Site and found two 2690 drivers for Windows Vista. www.lexmark.com >>Drivers and downloads >> enter printer model "Lexmark X2690" Select version of OS and type of driver you want.Should take you right to the two drivers I found.Don
Jun 14, 2009 | Lexmark X2690 All-In-One InkJet Printer
I have a carrier Jam!? It a lexmark x5320 I have tryed everything nothing works.
In this case unplug the Power Supply from the Printer...............
Take Out both the catridges from the Printer.................
Move the Catridge Carrier which holds the Catridges inside the Printer from left to right and from right to left for about 20 Times.......................
now insert both the catridges inside the Printer and Plug in the Power Supply and see whether you get the error message again.................
If u still have that error message please Call lexmark:
1-800-LEXMARK (539-6275)
Just call this number because the Enchoder strip has to be replaced........
Good Luck
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Cartridge error
In this case make sure that the catridges are inserted in the right slot...... The Colour Catridge should go in the right side and the black Catridges should go on the left side.... Make sure the catridge which u are using on this printer is the right one.......... It should not be a refilled cartridge if it is it will not work because Lexmark printers are not designed to work with Refilled catridges it may damage ur Printer......... If everything here is fine just take out both the catridges...... Take a Dry Paper Towel........ Clean the copper contacts on the printer as well as the Catridges....... Unplug the Power Supply from the Printer............ Replug it in and if still it says catridge is missing then may be a problem with the catridges.............. Hope it Works..... Good Luck........
Jan 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
Driver for Printer Lexmark X 2690
http://www.downloadsource.net/19100/Lexmark-X2600-X2620-X2630-X2650-X2690-Driver-Windows-2000-Vista-32-bit-XP-32-bit/ go to the above link and scroll down the page and click on down load and this will fix it
Nov 02, 2008 | Kodak Personal Picture Maker PM100 InkJet...
Lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
103 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
