Question about GE DBSR453EBWW Electric Dryer
Ge dpsr475gwoaa gas dryer.
When it is first started i get a sweaking noise like something rubbing metal. The noise quits after a few minutes. The belt is intact. suggestions.
  • 686 Answers
Rear bearing is dried up needs to be taken apart and re-greased with high temp grease
Posted on Feb 27, 2009
Forgot lint trap, dryer making noise immediately after. Cleaned vent and blower wheel and housing- still making noise. What else could it be??
If its like a grateing metal on metal it sounds like the rear bearing has worn through which is quite common.
hope this helps a bit
Jun 24, 2016 | Dryers
GE dryer DCVH515 - making noise when in use - metal rubbing? Any thoughts?
Hi peggymaag...
You have drum rollers that need lubrication or replacement...also you felt seal at the door may need to be replace if it is a metal to metal contact that is making the metal rubbing noise or it could be the drum bearing is going bad and making the metal noise you hear.
I will include a webpage so you can see your dryer and order the parts necessary for the repair of your dryer
Please take time to rate me 4 thumbs up
http://www.partselect.com/MultiModels.aspx?ModelNum=dcvh515gf&searchTerm=&RefineSearch=0
Sep 03, 2011 | GE DCVH515GF Gas Dryer
The dryer will make a loud scretching noise like metal rubbing on metal and then after about 10 minutes the dryer will shut off and when you try to restart pushing the timer/start button, it just make a...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 31, 2011 | Dryers
Whirlpool Dryer squeals
Either the drum is rubbing against something or more likely the belt pulley is cause the noise. Oil the pulley wheel and the drum rollers and it should stop squealing.
Dec 14, 2009 | Dryers
Ge gas dryer that sweaks as drum rotates. the heavier the load the louder the noise
the drum sits on a couple of roller bearings. thats where the squeak is coming from. its a couple of hour job to change them. as far as dryer repairs go this is big job. I recommend finding a new machine although it will still work for quite a while.
Aug 23, 2009 | Dryers
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
Heating Problem
If this is a gas dryer, you probably have bad valve coils, they can work intermittently, usually for the first part of a cycle, but when they heat up the internal resistance gets too high and they fail to open the gas valve. Once they cool off, (by continuing to air dry) they will work again for a few minutes. They will also make a buzzing/rattling (maybe "metal" ) noise as voltage is applied. For any Kenmore gas dryer, get part #279834 it contains both valve coils. Very easy to replace. Another possibility is that your duct work is plugged, check airflow. Hope this helps.
Sep 14, 2008 | Kenmore Dryers
GE DBSR453EBWW Electric Dryer Logo
98 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
