I have just purchased a Benq Projector MS513P, when I plugged it all on, all was fine. I then switched it off, when I plugged it in again, it projector is not picking up my laptop, show "no signal". I then plugged in another laptop, all was fine, when switched off and switched on again, "no signal". Please help.
SOURCE: Resetting the lightbulb in my benq projector
press and hold exit button for 3 seconds or more and OSD will pop up, then follow instructions
SOURCE: BenQ MP610 password???
Hi, i have a problem with MP610 i lost password and i can give you the code num 22654 15072 7440 9690
SOURCE: I have a DLP Benq projector (not sure the model
go into the menu and reset the settings to factory default. after that, select computer again and see if it recognizes it. you may need to change the resolution to match the laptop.
SOURCE: my benq projector keeps shutting off after about
are any of the leds lit? are the fans still running? if not, you have a power supply issue, and it needs replacing.
SOURCE: Projector shuts down ca 20 sec from start.
I have the same problem, however, my lamp wasn't replaced. Projector working great, just started today. Filter cleaned, reset lamp time, neither helped. Any luck yet?
Resetting the lamp counter
i. Press and hold the Exit 5 button on the projector for 5
seconds to display the total used lamp time.
ii. Press Auto on the projector or on the remote control to
reset the lamp hour to "0".
iii. Wait about 5 seconds to let the OSD disappear.
