Question about Dell OptiPlex GX200 PC Desktop
My dell optiplex gx200 bios can't boot
after a virus infection, i try to reformat my HDD and reinstall a new OS (windows XP SP2) but my dell optiplex gx200 can't boot the original bios. i am receiving the following message: ''previous attempts in booting this system have failed at checkpoint EMem...''
Can somebody tell me what to do. I try the dell support team already but no relevant help.
  • aldac12 Feb 19, 2009
    hello 2dcapcom,
    Thankx alot for your help. I have tried removing and replacing the battery, but still receiving the same error message.
    I read somewhere in this site that flashing the upgrading to the latest bios version can help. Question: how can i have this done without a boot disket since the floppy drive isn't working? Can I create a boot cdrom and how do i procede?
    Thankx in advance
    al.
  • zkolawole Apr 06, 2009
    The older window on my pc has been curropted ...l tried to reinstall by repairing ,but it would't even boot the setup...help me out.
  • 51 Answers
Maybe try taking out the cmos battery located in your case, looks like a small watch battery, that will clear bios settings and start from scratch, if there is no battery then there is a jumper sequence to do this
Posted on Feb 17, 2009
  • 2dcapcom
    2dcapcom Feb 19, 2009
    so to clarify your computer won't boot from cd?
    your computer won't boot to the original installation of xp?
    you were not able to do your format and restore?
    you can't get into bios?
    basically what happens is you boot up and it goes to this "failed at checkpoint message"?
My dell optiplex gx110 wont boot, it stops at the xp logo, i am running windows xp
Windows gone corrupt, might be infected by virus, need to re-install, from recovery CD or by windows xp CD.
Good luck, do rate the solution if got help
Dec 02, 2010 | Dell Optiplex GX110 (2909T) Motherboard
Hi my computer dell gx280 didn't work. It keep show "no boot device available". i try to replace with new hard drive but it still show same thing. Can you help me figure out what is problem with it please?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Try the above solution and let me know how you get on?
Jul 04, 2010 | Dell OptiPlex GX280 PC Desktop
My hdd does not get detected
I too had a similar problem with my laptop. My laptop had a virus attack and somehow I managed to remove all the viruses. However there was one persistent problem which was while booting, My documents used to open automatically. Hence I wanted to repair the Windows XP SP2 and so I went to BIOS and changed the settings to boot from CDROM. While booting the installation CD from CDROM, suddenly I get a message: Hard disk not found! This was nightmare. Then I got this solution:
My laptop was new and the HDD was connected to motherboard with SATA, and we need SATA drivers before installing OS. In the likely event of not getting this driver, we could still solve this problem by confusing the computer. Go to BIOS settings and change the SATA to IDE or any other. Then restart the computer. The HDD now can be seen and you can repair or reinstall the Windows XP SP2.
Aug 12, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
Virus
Don't reformat it just yet. Tell us what OS you are using, and I can try to help.
I will assume you are using WIndows XP or Vista - what you can do, assuming you have kept your PC up-to-date, is try to run the inbuilt Microsoft anti-malware program.
Click Start, Run, type MRT and press Enter or click OK.
You should get the February 2009 version of the Microsoft Malicious Software Removal Tool.
Do a quick scan and see what comes up. If anything is found, reboot and repeat the process doing a full scan (can take several hours).
That should fix and remove the most common virus infections. Let me know how you get on.
If you still need to reformat, you need to use the Dell recovery CDs that came with your laptop. These were a blue recovery/drivers CD and a purple CD for Windows XP sp1 or a green CD for Windows XP sp2. Not sure about other versions of Windows. There is no magic button to reformat with Dell laptops.
Feb 16, 2009 | Dell Latitude D600 Notebook
Boot problem with Dell Optiplex GX150
To reinstall Xp from the CD you need to press F2 and go into the BIOS then select the boot order configuration and make the CD the first boot device and the hard disk the second boot device.
After installing XP, if you wish you can go back into the BIOS and change the boot order to boot from the hard disk first.
Dec 13, 2008 | Dell System Board for Optiplex GX 150,...
I have a P III with 40 GB HDD and 384 MB RAM My motherboard is a Intel chipset - 6B810ECD (2M) -B0 I am not able to boot up the OS (xp) . It boots upto the Bios display and doesn't gets past that
Please try to login through the safe mode by press F8 key at booting time. and if doesn't get success than try to reinstall windows xp without sp2. Please some p3 system doesn't support win xp with sp2.This might definately solve your problem.Feel free to revert. Rest assured
Dec 04, 2008 | Computers & Internet
Hi hope u can help atleast ...
That is a simple problem with a difficult answer. The bios has been infected by a virus that has placed its self in the chip. You need to flash the bios chip which is very diffcult on a laptop motherboard.
Take the motherboard completely out of the casing. Find the bios battery and remove it and keep it removed for about an hour, come back to it replace the battery and then try to reinstall xp home. If this continues you'll need to wipe the bios and reinstall it and that is more or less a waste of time and a pain in the backside.
Aug 19, 2008 | Intel Motherboard
Dell Latitude will not boot
Reseat the hard drive and then get into bios and check if the hdd is detected ,if not you need to replace the hdd ,if detected reinstall the OS.
Apr 03, 2008 | Dell Latitude C600 Notebook
Unable to get back from standby.
In your problem there is no errors in the hardware, You may/should reformat and reinstall the windows to correct all the errors.
note: reformatting and installation can delete your files so back up it b4 proceeding.
Jan 22, 2008 | Intel D101GGC Motherboard
Dell OptiPlex GX200 PC Desktop Logo
1,277 people viewed this question
Alun Cox
