Question about GPX KL858S 8.1 in. Under Cabinet TV
My GPX 8.1 dvd/cd player stopped working. I have had it a very short time. Manual is missing. Radio works, but nothing else. How can I address this issue?
  • prettiestcat Feb 17, 2009
    Is there an answer for this?
  • 10 Answers
SOURCE: The radio works but the CD does not
Hi Could be a bad selector switch, try jiggling it back and forth to see in it works in an in between position. Possible loose power connector to the cd player or cd is faulty. Jay
Posted on Jan 21, 2008
SOURCE: remote codes
Radio Shack has a website for all of it's universal remote codes for the remotes it sells at www.rcinfo.com. There you'll find what you're looking for.
Posted on Sep 11, 2008
SOURCE: GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
Posted on Nov 18, 2008
SOURCE: GPX Radio Alarm Clock CD
I emailed the company and they sent back a pdf of the instruction manual to me the same day.
partsinfo@dpi-global.com
Posted on Nov 25, 2008
SOURCE: Need owner's manual for GPX under-cabinet radio CD player
http://www.gpx.com/
then go to support
Posted on Dec 26, 2008
Need Manual for GPX model 8544
some wont play copies mine wont
Apr 13, 2015 | Televison & Video
How do i get the FM radio to work on my GPX 60 sec portable cd player
After some research, I even read the instruction manual, I found no evidence of an FM tuner in the unit. If you instruction manual say's it does, it should instruct you on how to enable it. I found on the Amazon site no advertisement of an FM tuner as well in the specifications.
Feb 15, 2011 | GPX C3960 Personal CD Player
Controls for radio/cd player work on and off.
I had similar issues with my audio being mute intermittenly. I ended up being a penny in the CD player slot. (I think the previous owners kid put a penny thru the CD player slot) It also shorted out my DVD system, the DVD player would not come on. The dealership where I bought it seen me to GV Electronics to have my DVD player replaced, and they removed my CD Player and heard change banging around in the Player. After dis assembling it, they found the penny. Everytime I hit a bump or go over railroad tracks, the audio would mute.
Aug 18, 2009 | 2004 Nissan Quest
Why did it stop working?
It most likely needs a new battery. Take it to a radio shack store and they will install the battery for you as long as you buy it there.
Apr 01, 2009 | GPX D1816 DVD Player
GPX portable dvd player does not play on bigger tv with rca cable
You have to buy the $15 video cable from GPX. I tried several differant cables including RCA to S Video as a last resort. They say theirs is propritary and I now believe it!!!
Jan 01, 2009 | GPX PD708B Portable DVD Player
GPX PD808B Portable DVD Player
The pin on a regular 3.5mm av to rca is TOO SHORT. If you get the unit from GPX, you'll note it is a bit longer. I found this problem also affected Sony and other portable DVD players - the regular 3.5mm plug is TOO SHORT. I haven't found a source other than GPX for the av cable with the correct length plug. Weird but true.
Sep 02, 2008 | GPX PD808B Portable DVD Player with Screen
Player won't work
i am afraid it is a defective player
alot of cheap dvd player are on the market
even sony player goes bad.
they made them cheap and fast.
if it gave you more than 4 month of service then
it was worth the money
time for a replacment
Aug 16, 2008 | GPX PDL805 Portable DVD Player
Feb 23, 2008 | GPX CRCD6306DT Clock Radio
GPX PDL805
Usually when a DVD stops spinning that indicates that the laser did not detect the disk.
Unfortunately, that also usually means that laser isn't working or may be dirty.
I would blow out the inside really good and also clean the laser lens lightly with a q-tip and some rubbing alcohol.
If it still doesn't work then it's probably time for a new one.
Feb 18, 2008 | GPX PDL805 Portable DVD Player
GPX KL858S 8.1 in. Under Cabinet TV Logo
95 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
