Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I have a TV of philips "CCB130 or 132 or190 or192 AT.(one of them
And have a question.Do I need to do something for a digital transition for my TV?
  • 8,596 Answers
Yep - you will need either a digital cable or satellite box, or an analog-to-digital converter.
Posted on Feb 21, 2009
Watching tv and lost all channels
are you located in USA? If yes digital transition had done something but don't worry we are her to help you. a converter can do amazing thinks. buy a converter box from walmart and then all will go well!!!
Sep 23, 2009 | Protron PLTV3250 32 in. LCD Television
My VCR not recording after the switch to digital tv signal
The answer to this question can get a little complicated. Lets tackle it in two parts. First the last part; the part about picking up channels as decimals. With analog TV transmission, it took the full television broadcast channel to transmit one standard definition TV program. The newer digital transmission system uses some advanced video compression and audio compression technology to reduce the data needed to transmit the pictures and sound which allows the same bandwidth to deliver either High Definition Television programming or MULTIPLE channels of Standard Definition programs. So in your example above, you use to watch one channel of programming on TV channel 4, but now the TV station can broadcast multiple channels of programming on channel 4, sot they delineate the programs with a decimal point. So 4.1 it the first program on TV channel 4, 4.2 it the second program on TV channel 4..... Well, I hope you get the idea.
Now for the hard part of your question. I believe that before the transition, even with your new digital TV, you were still enjoying the analog broadcasts from your stations. Your VCR picked them up and recorded them and your digital TV could tune them in and you watched as you had always done in the past. After the transition you noticed that your VCR could not record anymore and your digital TV had discovered the digital channels that replace the analog channels. To remedy this situation, your VCR will need the aid of a DTV converter box to tune channels, and you may have to reconfigure the way your TV and VCR are connected. The best resource that I can give your for the reconnecting is the website http://www.fcc.gov/cgb/consumerfacts/converterbox_vcr.html. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Scroll down to the Normal 0 false false false MicrosoftInternetExplorer4 section about “Set-up #2: Watch One Channel while Recording a Different Channel”.
Hope this helps
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
After the digital transition, I lost one of the local channels. When I rescan, all of the other local channels come in no problem. ABC Channel 12 in Flint Michigan is gone. I had it no problem on...
Try the recommendations in a document posted on the FCC site (http://hraunfoss.fcc.gov/edocs_public/attachmatch/DOC-291403A1.doc)
Also be aware the several stations have had problems with the transition. Some changed frequencies on which they were transmitting and encountered area coverage issues that didn't meet their expectations. They have been working with the FCC to remedy the problems and many stations have temporarily increased output power to compensate for the issues. Some of these stations may be difficult to receive and you may need to get larger antenna. If you are still having problems call the FCC DTV transition hotline at 1-888-CALLFCC (1-888-225-5322) or the TV station for advice.
Jun 13, 2009 | Pbi HD3150 DTV Receiver
I need to register my mp3 player
Philips is under construction/in transition - call the 800 number and register over the phone. I can tell you what I know about product registrations - they are worthless. Save your receipt, since it will be required for any situation save for the very beginning of your warranty period (if that).
-Tha Mp3 Doctor
Dec 25, 2008 | Philips GoGear SA178 MP3 Player
Magnavox 27mdtr20 17
The Magnavox 27mdtr20/17 is a standard def. television produced in 2003 by the Philips-Magnavox Corporation. This particular model was conceptualized long before DTV was an option, and much further before Digital Television Broadcasts were considered a viable option for our current current communications problems.
You will need a DTV box IF:
A) You use an antenna (roof top or otherwise) to watch television
You will not need a DTV converter box IF:
A) You subscribe to cable services, either analog or digital
B) You subscribe to satalite services
For more information on the reasons behind the DTV transition, as well as getting valuable cupons from the federal government to help subsidize the cost of a DTV box, please visit this site:
https://www.dtv2009.gov/
I hope this helped,
Remy
Dec 23, 2008 | Philips 27MDTR20 27 in. TV/VCR/DVD Combo
Digital ready?
Sanyo's customer service responded that this TV is not digital. If it's connected to an antenna, you will need to purchase a Digital to Analog converter box.
May 11, 2008 | Sanyo DS19310 19" TV
Philips CCB130AT02 TV/VCR combo
Is this an Analog TV? Does it have a picture tube and not an LCD or plasma screen? Most likely this is a Analog TV.
If it is an Analog TV (and I would bet that it is), then no, it does not have a digital (QAM) tuner to pick up DTV broadcasts. The fact that it has a VCR also indicates that its an Analog TV.
If you are picking up your TV signals from an outside antenna and not cable, then yes, you will need a converter box to convert the new digital signals to Analog so that you can continue to use your TV set.
If you are using cable to receive your channels, the cable company already provides the conversion for you and your TV will continue to work as before.
The government is giving out coupons to help consumers defray the costs of purchaing a converter box. The following sites are good places to obtain more information.
www.ntia.doc.gov/dtvcoupon
www.DTVanswers.com
- Jim
Feb 06, 2008 | Televison & Video
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
