Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Need to silence ringer and have it pick up on first ring
How can we either silence the ringer and/or have it pick up the incoming fax on the first ring on the Brother Intellifax 775?
    Problem Solver:
  • 19 Answers
Menu, receive option, delay ring, options 0-4 choose 0! Done
Posted on Mar 20, 2009
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Dell 2135CN cuts-off incoming calls to my home phone number after 2 rings and the call goes to the printer. I hear the ringer inside printer, then hear fax tones, even though the call is not a fax. My...
Hi and welcome to FixYa!
Well if that's the case, the printer should be detached or powered of during call operations. The printer detects incoming calls that's why it triggers it to operate. Turning it off during operation will surely be the solution.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 05, 2011 | Computers & Internet
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
The phone does not ring - ringer is off.
firstly read the operations manual for that phone look on how to adjust the settings of your phone it probably sure was indicated there, because the way i see from what you posted it has no internal circuitry prob. it just needed an adjustment.. hope this advice helps... ;-)
May 24, 2009 | Panasonic KX-TG2343 Cordless Phone
We cannot receive incoming faxes without first picking up the phone and then hitting the start button - how do we get the fax machine to work automatically.
Should be in the operators manual. You need to change the setting, through the control panel, to "autoanswer". You can print out the current settings by pressing the "menu" button, scrolling to "user settings" and print from there. You can also select the number of rings before the machine picks up, and the volume of the ringer.
Dan
Jan 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Turn off fax ringer - turn on phone ringer Laserclass 2060P
Hi
You can set it for manual mode.
Or set it for fax only but set the incomming ring count to more than 8 times that will give you time to answer a call before it go to fax.
Jan 05, 2009 | Canon LaserClass 2060P Plain Paper Fax
Why is my phone ringing?
Your Handset has been programmed i guess by mistake to be in the same ring group as the main receptionist for C0-01 . Use Google for programming manual to make changes.
www.heymot.co.uk
Oct 17, 2008 | Panasonic KX-T7633 Corded Phone
How do you turn off the ringer
On printer control panel, select setup, then select #4 (basic fax setup), then #6 (ring & beep volume). Select OK, then press either the left or right arrow until "OFF" appears - then press OK. This will turn off the ringer for the fax machine and will also silence the keypad tones.
Jul 10, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Incoming Phone Ringer
After months of trying to solve this problem I finally figured out that the machine was set to phone/fax mode instead of fax only. If you have a dedicated fax line you can set to FAX ONLY MODE. In FAX ONLY MODE you can control whether or not the machine rings when it receives a fax call. You do this by selecting Data Registration, Press Set and use the up and down arrows to select 4. RX Settings. Press Set and use the up and down arrows to display the item you want to set or change and turn the ringer OFF. Press Set.
Mar 26, 2008 | Canon LaserClass 2050 Plain Paper Fax
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
231 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
