Question about Dell Dimension E310 PC Desktop
Dell dimension E310 wont boot
Hi my Dell dimension got infected by ms anti spyware2009, it won't let me do anything. so i restore it to Manufacture setting by doing ctrl_F11.
the process complete, but it won't boot, it show dell logo then window Xp logo then the screen goes blank then then (monitor light goes orange) means no connection.
I put this HD to my second HP desktop it boot all the way.
I try to boot several times the same situation.
so I unplug the HD, then put my old HD with window 98, it boot all the way to desktop with out the proper driver.
any advice will be advice appreciated, thanks
  • 2 more comments
  • newtoytown Feb 17, 2009
    my bios don't have sata to IDE option
    I just try to boot and press F8 to safe mode it work, boot all the way to desktop, when I restart. it when back to the same problem.
    Question: on safe mode I have all this option:
    1 safe mode
    2 safe mode w/ networking
    3 safemode w/ command prompt
    4 Enable boot logging
    5 Enable VGA mode
    6 Last known good config(your most recent setting that worked)
    7 DIRECTORY SERVICES RESTORE MODE (WINDOW DOMAIN CONTROLLERS ONLY)
    8 DISABLE AUTOMATIC RESTART ON SYSTEM FAILURE
    9 START WINDOW NORMALLY
    10 REBOOT
    11 return to OS choices menu
    thank you removing the video card solve the problem, it boot all the way to desktop thanks
  • newtoytown Feb 18, 2009
    Thanks for your help, my computer is up and running good as new
    thanks again
  • 479 Answers
Go in bios and change the SATA mode to IDE or compaitibilty then check whether it is working or not
Posted on Feb 17, 2009
  • Gyanendra Kumar Feb 17, 2009
    First of all u please run the full recovery means by a cd and breaking the partitions.
    If then also the issue is same check the machine with minimal boot and then add the devices one by one.
    U will be able to diagnose the root cause as the machine is going off on xp logo so does not seem the mainboard or HDD issue.
  • Gyanendra Kumar Feb 18, 2009
    Thanks for the rating.
Dimension E310 6 beep
if the beep pattern and led light pattern it's a memory problem, try reseating the RAM. Problem and solution is described multiple times here
Dimension E310 won boot up 6 beeps
21.June.2015
Apr 18, 2014 | Dell Dimension 5150 (DIM515MIN) PC Desktop
After I boot up my computer all that brings is just a by screen saver with nothing else no icons or anything. Any help would be great.
For some reason it seems that explorer.exe isn't start. I would start by rebooting into safemode. After the bios boot screen, but before the windows loading screen repeatedly press F8 to bring up a menu. Try safe mode with networking first and run an anti-virus scanner. Usually virii and other malware tend to do this.
Jan 08, 2014 | Dell Dimension E310 PC Desktop
Dell dimension e310 desktop error message unmountable boot volu me
> unmountable
The disk-drive cannot be "mounted", i.e., the motherboard cannot access it
> boot volume
To "boot" a computer is to load a small "loader" program from the disk-drive;
that program "pulls-up-by-the-boot-straps", to read the rest of Windows from the disk-drive.
If the disk-drive has "failed", then you'll get messages like the one that you reported.
Replace the disk-drive.
Jun 12, 2011 | Dell Dimension E310 PC Desktop
I have a dell dimension e310 desktop i beleive and it will not boot up. when i start it i hear 2 beeps. does this mean the motherboard is dead or what?
Two beeps means your motherboard RAM having some problem.
If you have two RAM install .Try to remove one and keep another .
Start your system and chek , if still problem is not solve better to contact with tech person.
Thanks for using FixYa.
May 20, 2011 | Dell Dimension E310 PC Desktop
I do not have my dell system recovery cd for my dell desktop deminsion E310 I need to to a recovery back to the factory state can this be done without the CD?
YES WHEN YOU BOOT UP LOOK AT THE OPTIONS,HAVE TO DO IT
FAST IT WOULD BE UNDER RECOVERY OR YOU CAN SCAN FOR PROBLEMS
LOOK AT THE OPTIONS IT SHOULD SAY RESTORE TO FACTORY CONDITION BUT YOU WILL HAVE TO HAVE A USB HARD DRIVE WHICH IS EASIER TO SAVE ALL YOUR PERSONAL STUFF MAKE SURE YOU TAKE YOUR TIME AND DON'T MISS ANYTHING THAT'S INPOTANT TO YOU FIRST.THAT'S WHAT I DID.GOOD LUCK
Feb 13, 2011 | Dell Dimension E310 PC Desktop
Hi. I have a dell e310...and the desk top turns on but the monitor will not display anything...it has an amber light..sometimes.it will turn to green but then shuts off again Could this be a bad video...
depends . either the video card or motherboard see if the blue video connector is at the top or twords the bottom of the case and that will tell you if it's a card or integrated on the board.
May 13, 2010 | Dell Dimension E310 PC Desktop
System password error
This password thats its asking for is upon first boot I assume before windows even trys to load. If thats the case theres a jumper on the motherboard that lets you reset the bios/cmos killing out the password and setting it back to factory stardards. You will have to goto dell.com and hit up there support section for a manual on were exactly its located but this will fix your password issue.
Mar 19, 2009 | Dell Dimension E310 PC Desktop
Dell E310 Dimension that won't go on!
Boot the computer into safe mode. Run full-system anti-virus scans to ensure that the system is virus free and to remove any infections that may be present. Reboot system.
Instructions for booting into safe mode:
1) Start system
2) As system is starting, press F8 key
3) Boot menu will come up asking how you want to boot - choose Safe Mode and press ENTER
4) Your computer will start with limited services, no internet connection, etc. This will allow you to check the system and scan for viruses without interference from non-essential services.
Let us know how it turns out.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | Dell Dimension E310 PC Desktop
Floppy diskette seek failure
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Jan 03, 2009 | Dell Dimension E310 PC Desktop
Dell Dimension E310 PC Desktop Logo
796 people viewed this question
Alun Cox
