Question about Sanyo DS31590 31" TV
Is there a way to turn off the speakers?
I want to run this into my stereo using surround speakers. Is there a way to turn off the built-in speakers?
  • stevekeutzer Feb 22, 2009
    Thanks for the info. As it turned out, the answer was right under my nose. Simply turning down the volume does not affect the output to the speakers.
There are several ways, you can either take apart the set and disconnect the speakers cables from the board or you can find and cut the power source where the audio chip amplifier is located that way the amplifier chip wont power on and will not feed the speakers
Posted on Feb 17, 2009
  • johnny-750 Feb 17, 2009
    you need to cut out the +vdd which is the power b+ source you can find a helpful link right here:http://www.tpub.com/content/neets/14180/...
Center speaker problem on pioneer vsx 40 .I hooked up the center speaker and I can’t get sound from it
Most problems are menu settings, because surround modes can be complex and confusing. Verify what surround input type you are using. FM tuner will not play center spkr unless put into a simulate or expand stereo mode. Do other surround speakers work other than normal L/R stereo mode? You can try redoing your auto surround setup (MCACC) or going to the manual speaker setup and verifying speaker is turned on in menu system. Rechech you listening mode setups at Pages 33,38,39 in your manual. Try another speaker and wiring on center output. Try Different surround inputs, some manufactuers have had problems with their DTS and HDMI boards. Otherwise take to repair.
Nov 22, 2017 | Pioneer Audio Players & Recorders
The audio keeps going in and out and cuts off. Also I have other devices going into aux in but it doesn't show 5.1 surround it only shows the front L, Front R, and CT speakers in stereo. I want everything...
If you are playing a source that is Stereo such as FM Radio or a CD the sound will not use all 5.1 speakers unless you enable the correct Surround Mode. On the remote there is a button on the lower right of the remote that says SURROUND. You can toggle through the various surround modes with this button the mode you want is Dolby Pro Logic The Pro Logic mode uses the built-in circuit to steer the Left, Center, Right and Mono Surround channel audio signals and uses all five speakers to play both stereo and Dolby Pro Logic program source, such as TV and VCR. You can use this mode with any stereo program source (such as VCR/TV) to enjoy multi-channel sound experience.
Mar 02, 2011 | RCA RTD317W Theater System
How do I connect to an external speaker, for better output from my LG LCD 42 inch?
It sounds like you are wanting better sound on your home theater.
If this is the case, you can invest in a surround sound receiver and run audio from your sources to the receiver (rather than to the tv).
Basically you would hook your cable/satellite, dvd/bluray, and other items into the surround sound receiver using HDMI, Optical, or RCA-style Stereo wiring.
Once this is done, you can run a single HDMI from your surround sound to your television for the crisp awesome video that your LCD will produce!
If you are looking to run an external speaker directly from your television, it has to be powered on its own, as the television's output audio isnt that strong.
In essence what you would be purchasing is a very wide bar (that is a speaker) that is powered, and has an audio processor built right in!
These are the solutions that I would recommend. If you appreciate them, please vote!
Feb 23, 2011 | Televison & Video
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I have new computer. My Yamaha speakers Model YST-M7 are older. There is power to the speakers but no sound is coming out. Not sure which hole to plug them into. My choices are: rear l/r surround...
Use the "line-out" connector (usually it's light green in color), and if there is an audio control panel application, make sure the sound circuitry is set for "two-channel" or regular stereo speaker operation. It can be confusing on newer computers which have surround-sound capability built in. Depending on how you set up the sound, the jacks can have different functions. But the line-out jack is what you'll use with basic speakers such as yours.
Dec 28, 2010 | Yamaha YST-M7 Computer Speakers
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
Dec 27, 2009 | Coby DVD-937 5.1 Channel DVD...
I have an Harman kardon receiver (avr 310) it only plays in left and rigth speaker with surround off . I try everything to make it work in other but it can't .
Surround only works from a surround source such as Pro Logic.
If you are useing a regular stereo source with surround off, the sound will come only from L/R speakers (and sub woofer if used)
Apr 22, 2008 | Audio Players & Recorders
Sound problem
I have a creative SoundBlaster LIVE! 24 Bit External Sound Card and this annoyed me for weeks.
depending on your surround sound reciever depends on the solution.
i have an Acoustic Solutions surround sound system with coxial and optical inputs, aswell as stereo red & white jack inputs.
not knowing the method or connection your using makes it difficult to give you a single solution so i'll list a few.
The soundblaster software shoudl include the Creative Audio console with all sorts of effects, one is CMSS (CMSS-3D) Stereo widening which is still stereo but gives a surround sound effect.. but i'm guessing you payed for 5.1 and you want 5.1 onto the next part
5.1 surround sound can only be produced when the actuall audio your playing contains 5 channels of audio, for example you cant play a stereo song in 5.1 surround sound without some sort of hardware or software sound manipulation. Luckily my surround sound system has Pro Logic II built in and some other effects which convert a 2.1 signal to a 5.1 signal and it works brilliantly. I'm not sure of a software alternative.
setup for your soundcard will be different under XP and Vista also, but there should be a properties option for your sound device where you can select your speaker setup such as headphones, built in speakers, 2.1 speakers, 5.1 speakers, 7.1 speakers and you should be able to manage this from the creative software.
If using Coxial / Optical or SPDIF under vista you MUST set the playback device as SPDIF, at least you have to with my sound card and drivers and seems to be a limitation of the actual sound card drivers for vista.
Personally i was looking forward to hearing the windows login melody in 5.1 surround sound too, but this doesnt happen.
Infact i find that almost all programs bar a few will not play Dolby Digital or DTS 5.1 surround sound via any or my output options hence the next solution..
if you have the 5.1 sound but winamp simply just plays it in stereo try the following.
You need to use DirectSound Output:
Preferences (Ctrl-P) > Plug-ins > Output > Select "DirectSound Output"
That should work in most cases, but if not, then:
Checkmark: "Allow hardware acceleration" in DirectSound Output config,
and make sure your sound card/chip is selected as Output Device.
Note that any changes will take effect only after playback is restarted.
In some cases, a Winamp restart is required.
If that doesn't work make sure you have the latest version of DirectX
(v8.x or higher is required)
Winamp 5.25/5.3 and higher:
For actual multi-channel files (ie. aac/wav/ac3/ogg/wma files encoded in 5.1ch surround, as opposed to standard 2-channel stereo mp3's), you need to checkmark "Allow surround sound" in 'Winamp > Prefs > Playback' for the music to play in its original 5.1 channel format (Note that this setting is checkmarked by default).
Windows Vista:
In addition to the above instructions, Vista users will also need to go to:
Control Panel > Sound > Playback tab > Speakers > Configure:
Select: 5.1/7.1 Surround.
Then:
Control Panel > Sound > Playback tab > Speakers > Properties > Enhancements tab
and checkmark "Speaker Fill"
Hope this helps
Anthony Kinson
Speakers in a toshiba 35 tube blown
I spent hte whole day moving my girlfriend and the only thing I got out of it was a TV with no sound coming out of it. I turned the speakers "on" in the menu screen, then i used the speaker output of the tv to a stereo or a couple of cheap speakers. Or connect 1 speaker and set the tv to mono. Hopefully your tv has some form of audio out besides the built in speakers. Good Luck
CN
Feb 20, 2008 | Toshiba 35A44 35" TV
Sanyo DS31590 31" TV Logo
115 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
