Question about Hitachi 500GB External USB 2.0 Hard Drive
How do I recover data from a dead drive
My Hitachi external drive all the sudden is no longer recognized by my computer and I lost all my data.How can I recover this?I have been told this is quite common and very little support if any has been aquired through Hitachi. The External USB drive stopped working and emits a three tone melodic pattern 39 times, pauses for a few seconds. Emits a similar 3 tones as the 1st 29 but at a lower pitch, then repeats the original pitch three tones.
The Hard Drive is not spinning.
I am an Electronics Engineer and tested the dive with a substitue power supply (orig is 12V dc at 18 watts, I substitued a 12Vdc @ 700ma) with the same result.
Looking for information on the tones.
No noises were ever made by the drive. It has worked perfectly until turin it on the other day and hearing the beep codes.
Hitachi support responded with:
> Hello Darl,
> Thank you for contacting Hitachi Global Storage Technologies.
> Our DFT (drive fitness tool) is not applicable for your external hard
> drive.
> I guessed you did already the necessary troubleshooting for the drive.
and would like it sent in.
I'd like to recover the data if I could figure what the codes indicate.
Any help is very much appreciated.
May have to take it to the Geek Squad.
--Darl
HITACHI Part Number = H3500U FRU Number = 0A35777 Serial Number = R40T99GH
  • 1 more comment
  • D-Lane Feb 18, 2009
    I'll drop in to device manager per the suggestion to see if the USB drivers are present. The drive does not spin up when turned on where before this failure mode it would regardless of connection to a USB cable. I'm hopeful and appreciate any suggestions to try and get this thing back to life.
    Thanks,
    D-Lane
  • D-Lane Feb 21, 2009
    rylee_smith: Thanks for your response to my delima!
    I tried connecting to my work PC (DELL) and it still plays it tones as listed in my problem description. I've tried three different PC's and none will detect that it's connected to the USB port and I have used the same USB port with different brands of USB travel drives.
    Still looking for othe ideas.
    Is it a choice to purchace an identical drive to then swap components to recover the data? Any procedures for this or does it require special equipment for "calibration" and alignment to be able to retrive the data.
    I tried rylee_smiths suggestion for the device manager though none of three known good PC's reconize the drive is connected. Any additional help is much appreciated.
    Thanks,
    Darl
  • 846 Answers
If the hard drive doesn't spin and you hear noise from the spindle motor it sounds like you may have a headcrash (head stuck to platter.) If you're courageous you can try to open the drive and try to spin the platter as you gently push the head off the platter. Technically you need a c100 clean room for this, it all depends on how important that data is for you. There are some good data recovery guides on youtube, especially the stuff from scott a. moulton. If you want to pay to have somebody do it for you there are third party Data Recovery Services.
Posted on Jul 26, 2010
    Scholar:
  • 164 Answers
Wow....
You could do allot of work and swap out the drive or open it and see if the bearings are frozen or: you can send it to a reputable company like we use at the AFB>
http://werecoverdata.com/landingpagegoogle.aspx?src=Google&gclid=CIeAu7mL7pgCFRWbnAod8CLK1A
Posted on Feb 21, 2009
  • 139 Answers
Hi just connect the hard drive with your system and go to my computer right and do a right click and in the option select manage
In themanage window go to disk management and check if the disk is detected or not.
If the disk is detected then right click on the drive and the assign a drive letter to your drive.
You will get all your data back
  • 1 more comment
  • Chetan Gupta Feb 21, 2009
    Secondly if the light blinks then the drive is detected and you have usb drivers. Now if the drive fails to come in my computer tell me I will give you a second option
    The second option is open google and type in get data back for ntfs or fat 32 and its gives you a free software by whic you can get your data back
    Just connect your hdd and let the software do its job
    President:
  • 2,653 Answers
First thing, don't take it to the Geek Squad, they are worthless. You'll need a professional Data Recovery company to retrieve the info. Usually the cost is $300-1000 depending on the damage, amount of files, price of tea in China, etc. etc.
One thing that you can try since your'e an Engineer is to remove the drive from the external casing and then hook it up via a usb cable to a computer. If you haven't done so already.
Also you could replace the main board on the hard drive. DO NOT OPEN THE HARD DRIVE. You will ruin it. That little board on the bottom can be replaced though very easily without affecting the drive. You need to find the EXACT part number of the board and then search ebay for either that board alone or a complete drive so that you can swap the boards. This works sometimes and it's A LOT cheaper than the pro route.
Also you could try using Knoppix to access the drive. Depending on the damage or what's going one with the drive you might get by with that.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The external storage device could be divided into 2 main sections:
  • the electronics (including power supply) and data interface;
  • the actual hard drive.
To verify that the electronics is faulty or not, the HD inside the Hitachi external must be physically removed and attached to a IDE/SATA to USB adapter and connected to your computer. If it runs, then the HD is good but the electronics/interface faulty.
On the other hand if with a separate USB adapter, the HD would still not be accessed/read, then it would be the hard drive itself that is faulty.
You could still use a file recovery program. while there could be equivalent freeware versions, I have had very good success with GetDataBack. Download a trial copy (NTFS and/or FAT) before purchase to ensure that said program can recover. The Demo will display files that could be recovered but will not effect copy of said recovered files.
Good luck and thank you for using FixYa.
Posted on Feb 17, 2009
    Top Expert:
  • Hitachi Master
  • 77,499 Answers
There are many companies on the internet that u can send your drive to and they can recover the info from the disk, have u tried looking?
    Brigadier General:
  • 8,619 Answers
Hi!
Are the usb drivers installed. Go to device manager to check them
  • Rylee Smith
    Rylee Smith Feb 24, 2009
    If a drive is not recognized then it is either contaminated by a virus or its partition information was deleted with FDISK.
    Please use this software to retrieve the information from your unrecognizedDisk drive--
    Data Recovery
    Thanks
    Rylee
  • Hitachi Master
  • 19,396 Answers
If the hard drive is beepoing, then it has broken heads.
  • Ginko
    Ginko Feb 17, 2009
    If the hard drive is beepoing, then it has broken heads or motor.
    This is called physical fault, and data recovery may be expensive.
    The beeping codes on hitachi are only for broken heads or broken motor, or logical board fault, bad sectors and similar do not cause beeping.
    That means that to recovery your data you need a device called clean room 100
    The service costs over $500
    A different thing is if the hard drive can be accessd by the system, but when it is beeping this is usually impossible.
  • Ginko
    Ginko Feb 17, 2009
    Below few company that can do this kind of data recovery. They can also help to diagnose the problem and give you a quote:
    Hitachi Data Recovery
    see also
    Recovering data from hard disk drives with motor failure ..
Computer won't recognize external hard drive anymore Hitachi lifestudio
Try connecting the external hard drive to another computer to recover/backup your data.
When you have such a large capacity hard drive, it pays to have a second large capacity hard drive to backup your data in the event of the other hard drive dying.Hard drives do fail especially if you accidently drop it.
Jun 07, 2012 | Hitachi 35IN LIFESTUDIO DESKTOP 2TB...
I Have a Hitachi Lifestudio hard drive attached to my Apple G5 for 7 months now, and suddenly just dessapear of my desktop or menu the Computer it won't recognize it anymore HELP!!!!!!
Jun 07, 2012 | Hitachi Lifestudio Desk Hlsdbub5001bbb 500...
Windows xp not recognize external hard drives
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover data from hard drive with data recovery software.I had succeed with Tenorshare data recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage, virus attack etc.
You can download it and scan your external hard drive for free to preview whether your files can be recovered.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to get it fixed.
Nov 05, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External harddrive not recognized by my computer. it worked fine for a week and then all of a sudden stopped being recognized by the computer. Do you have any idea why this would be. It is a windows vista...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
http://www.asoftech.com/adr/
May 24, 2011 | EDGE Tech Corp Edge 500GB DISKGO 2.5in....
I have an external hard drive 120GB , unfortunately it fell down, my PC can no longer recognize it, is there any possibility to retrieve all the files stored in it tnx
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
May 02, 2011 | Computers & Internet
My hitachi external hard drive can't be found by my laptop
Remove it and install it into another computer to see what'll happen.
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover data on it with data recovery program to avoid losing them.
I have succeed with Tenorshare data recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash and 'not recognized' issue.You can get it here: http://www.any-data-recovery.com/index.htm
After you recover your data,you can format it to check out whether it can be fixed.
If the hard drive can't be detected,you can try this way.Put it in a zip-lock bag and put it in the freezer overnight. Then while it's still cold plug it into the computer and you may be able to view it in 'my computer'. And run the recovery program to recover your data on it.
If it fails, you will have to go to a recovery office but let's hope not because it will cost you a lot of money and whether they can recover data is not guaranteed.
This article will help.
How To Recover Lost Data From Crashed Hard Drive?
http://tenorsharedatarecovery.blogspot.com/how-to-recover-lost-data-from-crashed.html
Feb 13, 2011 | Hitachi 500GB External USB 2.0 Hard Drive
Hard disk not recognised
When a hard drive makes a clicking noise, it is faulty. The clicking noise is the heads swinging back and forth. This hard drive is dead and the data is lost. If you desperately need to recover your data, there are companies that can recover and copy your data from faulty hard drives BUT it will cost you an arm and a leg for their services.
May 15, 2010 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
My Arc Disk 20 is suddenly no longer recognized by my computer and is making a clicking noise. I assume that it is failing but the light is still on. How can I recover info from that drive!
Clicking noise means hard drive physical damage. When that happens the data inside hard drive is lost.
If data is very important it can be sent to a recovery facility with a clean room 100, that is a special room where hard disk can be opened. The repair is over $600, and does not guarantee success.
Unless the data inside is really important, data inside hard disk (when clicking) is considered beyond recovery.
Jan 03, 2009 | Archos ARCDisk 20GB 4200rpm 480Mbps USB...
Maxtor III 500 GB external hard drive is no longer recognized by computer. No driver installed ???
Drivers are not necessary for hard drives - as long as your computer recognized it when you first installed it, you're all set. It sounds like your hard drive has failed, or become disconnected. Check the connections for IDE or SATA, and power. If they're both connected properly, listen when you power up the computer to hear if that particular hard drive spins up. If it doesn't, it might be dead.
If you have access to another computer, try installing the drive into it temporarily and see if it is recognized in that computer. If the drive has failed, you might be able to get it replaced by Maxtor if it's still under warranty. Unfortunately they will not recover any data on the drive for you; you must pay a data recovery specialist to recover any data on the drive, and this is expensive, so only do this if it's extremely important data.
Jun 10, 2008 | Computers & Internet
check cables attach... if still not working.. your hitachi may have been damage because your computer can't recognized it.
Jan 23, 2008 | Hitachi (EXT-USB400) (EXTUSB400) 400 GB...
Hitachi 500GB External USB 2.0 Hard Drive Logo
541 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
