Question about GE J2B915SS Dual Fuel (Electric and Gas) Kitchen Range
I have a ingus single oven and have lost the manuel I would like to know how to clean the top of the oven above the eleiment for the grill also how to clean the inside glass of the door
  • 1073 Answers
SOURCE: Exploding Door
replace the glass it has had a fracture to it in the production cycle at the factory
Posted on Jun 09, 2008
aborcass
  • 2651 Answers
SOURCE: Glass door GE JGS968
youlls need to remove the door forom the unit and disassemble the outer door glass, not a major deal, al ittle patience will get it done if oyou would like to know how to do it exaclty youll need to send me the model number so i can look it up for a part diagram..
Posted on Jan 16, 2009
danromarris
  • 101 Answers
SOURCE: GE Hotpoint electric stove
If you ran a self cleaning cycle and now the door won't open you may just need to wait a while. The door locks to avoid anyone from opening it as the over heats up to around 700 or more degrees to burn anything off. Sometimes what will happen however is that the heat will get to intense and cause the door lock mechanism to jamb. If the door doesn't open for you after a good few hours or so you can try unplugging the oven for a while to try and reset it. If not though you will have to go through the front panel and go down to manually unlock the door. Let me know if you have any other questions and let me know if this was helpful. Keep me updated on the outcome too if you wouldn't mind. Good luck and glad I could help.
Posted on Jan 22, 2009
SolutionGuy
  • 331 Answers
SOURCE: DO NOT KNOW HOW TO USE SELF CLEAN ON OVEN?
Hi April,
Without a model number, I'm shooting in the dark but I'll give you basic instructions that fit for most ovens, OK?
First off the door has to be locked PRIOR to cleaning. Look around the top of the oven door, there should be a handle (for mechanical models). Rotate this handle from the left to the right to lock it. If there's no handle, that means your oven locks the door by itself when "Clean Mode" is selected.
Now, at the control panel, select "Clean". At this point, you may have options on the length of time it should clean, select 3 hours and hit "Start".
There ya go! Hope this helps. If not, DON'T RATE THIS SOLUTION! Just write back and provide the model number, I'll give you exact instructions with that. Deal? Cool.
SG
Posted on Mar 23, 2009
DeBruce
  • 145 Answers
SOURCE: top of oven door is turning brown
DeBruce Polish will remove these problems on both stainless steel and enamel finishes. DeBruce Polish also works wonderfully on ceramic cook tops. DeBruce Polish is non-toxic, odor-less and non--abrasive, a true eco-friendly multi-surface cleaner. We get DeBruce Polish at debrucepolish.com.
Posted on Aug 26, 2009
Grill not working after replacement element - any ideas?
I would say you are right on your wondering. look at your manuel and it will show you a diagram
May 07, 2012 | Zanussi ZHQ575 Electric Double Oven
Have no signage on knob for top oven/grill..how do I know f it's grill or oven on when I turn it on?
If you turn the grill on, then only the top element will get hot in the oven.
if you select oven and it is fan assisted, then you will hear the fan working, and feel it blowing hot air.
Hope this helps.
Dec 24, 2009 | Belling XOU252 Electric Single Oven
How to clean inside top of oven above heating element
FIRST TURN OFF POWER THEN SPRAY TOP WITH OVEN CLEANER AND LEAVE OVERNIGHT THEN CLEAN WITH STRONG PLASTIC BRUSH NOT A WIRE BRUSH AS THIS WOULD CAUSE DAMAGE , WHEN FINISHED CLEANING WASH WITH WARM WATER ,
Nov 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
Cleaning above the grill element
I would not advise you to remove the element unless you feel competent to do so.
Best thing to do is to put the grill full on and let all the fat and grease burn itself off.
you will not hurt anything by doing this.
Make sure you have the griil door open and your house door.
Plz rate my solution.
thanks.
Dec 18, 2008 | Candy FP855 Electric Single Oven
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Nov 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Maytag oven keypad not working
my oven is not working, the grill works and the rangers too.
i don't know what to do .
please can you help me
thank you
Oct 20, 2008 | Maytag MEW5530D Electric Single Oven
Whirlpool 465 large capacity electric ceramic top oven failure
How much time I need to set to do the oven self cleaning ?
I have electric Whirpool oven 465 automatic
Oct 18, 2008 | Maytag MES5870A Electric Kitchen Range
Single oven not heating
diydoris, you would have to have someone ohm out the lower element to make sure it is good. If the element is good, then your problem probably is in the TCO. This is a thermostat that sits on the back of the oven that can go bad. You can test this with a meter, if it shows open (no continuity) its bad. Part number for the TC0 is 4450934. Part number for the element is 4448696. Catriver...post back.
Sep 27, 2006 | Whirlpool GBS277PD Electric Single Oven
GE J2B915SS Dual Fuel (Electric and Gas) Kitchen Range Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
