Mitsubishi WD-52725 52". Rear Projection HDTV Logo
frank barzdis Posted on Feb 24, 2013
Mitsubishi tv will not turn on - Mitsubishi WD-52725 52". Rear Projection HDTV
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
4answers
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
2helpful
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
2answers
Mitsubishi LCD HDTV LT-40153 lost all sound... less than a year old
do nothing except reset, if in warranty call Mitsubishi.
1helpful
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
1helpful
Mitsubishi CK-32308 No sound on most stations
Turn off TV. Turn on TV, use remote to turn off SAP. Now I have sound on all stations.
3answers
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
1helpful
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
3helpful
Mitsubishi HD1080 TV will not turn on.
On my Mitsubishi WD65-613 it was 4 capacitors on the DM board. They are 1000mf 16v, replaced with 4 1000mf 25v. TV is working great.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
