Question about LG LHT854 Theater System
Lg home theater to lg plasma tv
All speaker will play if i'm playing a d.v.d but only three speakers will play if i'm trying to watch the regular tv. how do i get all speakers play when i'm watching the regular telivision
    Scholar:
  • 93 Answers
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Posted on Feb 17, 2009
LG HT355SD only 2 speakers work
It's normal for only 2 speakers to play if you are playing music or if the movie you are watching is not in Dolby Digital 5.1 format..
Dec 21, 2012 | LG HT355SD DVD-Home-Theater-System
I have a panasonic viera flat panel plasma tv and a samsung 5.1 ch blue ray home theater system and the speakers work fine on the home theater system while playing a dvd, but does not work when watching...
1. The easiest solution would be to connect a stereo RCA (red and white) cable to the audio output on the back of your TV.
2. Then connect the other end to the input on your home theater system.
3. Change the home theater system to the correct input.
Feb 12, 2011 | Samsung HTC550 Theater System
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
I can not get any audio from the hometheatre when turning on TV only the audio is coming out is from the regular TV speakers. However when playing a DVD or Ipod the audio is coming out from hometheatre...
hi,
connect your tvs or cable set-top box's digital audio out to the digital audio input of ur home theater. the select the corresponding input in the home theator.
or connect set -top box's to HDMI input 1 of ur home theater, and connect its HDMI out to ur tv. assign the corresponding inputs for the hdmi 1 in ur home theater.
ok
Dec 21, 2010 | LG LHB535 Theater System
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
Cannot hear regular tv through speakers
you need to purchase either rca cables or optical cable
Jan 18, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Desire Audio for Theater System when watching Tv.
Have you checked all the channels connected correctly refer to the user manual once.
Jun 25, 2008 | Durabrand STS92 System
DURABRAND HOME THEATER
if you have a cable box run the subwoofer thru that . should work fine but you will have to turn off sub to kill volume as its running thru cable box not the audio of the tv
Nov 06, 2007 | Durabrand HT-3915 System
Home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Oct 15, 2007 | LG 42PC5D Television
LG LHT854 Theater System Logo
366 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
