Question about ECS 945G-M3 (V3.0) Motherboard
I would like to sapier vhich processor's are compattibble with my motherboard ECS P4M800-M (3 PCI, 1 AGP, 1 CNR, 2 DDR DIMM, Audio, Video, LAN)
  • 285 Answers
Well there are probably hundreds of CPU's compatible with your motherboard. What you need to know is the kind of socket it has.
The most common are AM2(dualcore) and AM2+(quadcore) sockets.
You can just try some sites that let you build your own pc. if you then submit your motherboard there, in the next step you will get a list of ONLY cpu's that are compatible. But if you find one, you should still check.
You can find hundreds of sites just by googling "build costum pc" or something like that.
I hope this helps,
Yannick
Posted on Feb 18, 2009
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
What type of motherboard for HP Compaq dc5700
The motherboard that you have is : yale-UL6E,
  • view the manual:
    yale_manual.pdf (300 KB)
  • micro-atx form factor
  • Intel Pentium 4 HT processor
  • Intel Celeron processor
  • Socket 478
  • 800/533/400 Mhz front side bus
  • Intel 865-PE chipset
  • 4 DDR-DIMM slots for single or dual channel configurations
  • supports PC2100 (266 Mhz), PC2700 (333 Mhz), PC3200 (400 Mhz) DIMM modules
  • graphics: uses AGP card only
  • audio: integrated AC97 audio
  • lan: integrated 10/100BT ethernet
  • 1 AGP 4x/8x slot
  • 3 PCI slots
  • 8 USB ports (2 headers for 4 possible front I/O, 4 on back I/O) *
  • 2 IEEE 1394 ports (1 for front I/O, 1 on back I/O)
  • connectors for front headphones and microphone
Dec 14, 2009 | HP Computers & Internet
I need specs
Here is the specs of the mobo.
Product MPN MPN sv266m Key Features Form Factor dtrquestion.gif Micro ATX Compatibility PC Chipset dtrquestion.gif VIA ProSavageDDR KM266 Compatible Processors AMD Athlon Processor Max supported CPUs qty 1 Memory Memory Type dtrquestion.gif DDR SDRAM Max Supported RAM dtrquestion.gif 2 GB Audio / Video Audio Output dtrquestion.gif Sound Card Video Interface dtrquestion.gif AGP 4x Communication Networking Type Network adapter Other Features Chassis Type dtrquestion.gif Desktop Package Qty 1 Dimensions Depth 9.52 in. Width 8.97 in.
Dec 03, 2009 | Syntax SV266M Motherboard
Need jumper pin config settings for imperial gv 2003 i need to know what j-5 is for mostly
This MB is very similar to Intel 845 boards. The info is similar & if you had mentioned which jumper's, then maybe.. otherwise this is the specs of imperial:
143159 Imperial GV 20030812
Mat,no:143XXX IMPERIAL-GV200XXXXX E-Machines Socket 478 Processor Socket Type: mPGA478 Memory Type: Unbuffered DDR Synchronous DRAM (DDR SDRAM) Memory Speed: PC2100/PC1600 Memory Sockets: Two 184-pin 2.5 V DIMM sockets Maximum Memory: 2 GB 256Mbit Memory Support: Yes Front Side Bus: 400MHz Intel: Extreme Graphics (845) AGP Manufacturer: Intel Bus: AGP Chipset: Intel 845 Video RAM Type: Uses system memory Onboard Audio Configuration: Intel ICH AC 97 CODEC AC'97 Codec Device: AD1886 Audio Jacks: M, LI, LO, (Header) SO Speaker CD-In Connector: 1 Internal Spkr-Out/Line-Out/Headphone-Out/Mic-In Header: Yes Onboard LAN Onboard 10/100Mbps Ethernet LAN Supplier: Realtek RTL8100(B) Ethernet Configuration: Down(PCI) Wake-on-LAN, Wake-on-Ring: via PME#(PCI) .....................sodeep
Sep 13, 2009 | E-Machines Computers & Internet
Need VIA AC'97 Enhanced Audio Controller Driver
You probably need the M/soft UAA drivers first download and install them
Then go to device drivers right click driver with yellow mark on it and upgrade driver should go on net and find and install driver
Oct 06, 2008 | Computers & Internet
Driver on MB
You should be able to locate your drivers HERE
Hope that helps =)
Apr 10, 2008 | Intel Motherboard
ECS 945G-M3 (V3.0) Motherboard Logo
52 people viewed this question
Top ECS Computers & Internet Experts
David
David
mitch_3020
mitch_3020
Steven Wander
Steven Wander
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
