Question about Palm Tungsten E2 Handheld
Cant use stylus.
I had reset the unit. then when i tried to go into touchscreen, i was tapping the bullseye, then it froze up. I tried reseting again, and now the stylus can not tap anything. Only the manual enter buttons work. I can not get into my main screen.
  • 89 Answers
Unscrew the 4 torx screws on the back and remove the cover carefully.
Unplug the battery for 30 seconds. plug it back in and re- assemble the unit. Once it comes back on it will give you the chance to re calibrate the digitizer ( or you can now select it from the prefs menu)
If the touchscreen fails to repsond you will need a new digitizer.
You can purchase it from :
http://www.gethightech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=PA1634&Category_Code=DIG\
there is also a video on how to take it apart here
http://www.gethightech.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=RD
Posted on Mar 13, 2009
I need to reset my touchscreen car radio everything froze and the screen just stopped working
I was unable to retrieve the manual for your unit. I would unplug your car battery for an hour or so. I would then reattach the battery cables. This will hopefully reset your stereo. Now try to use your car stereo as you normally would. If this works you will have to set up the stereo again.
May 28, 2015 | Power Acoustik POWER ACOUSTIC PD-931NBT...
HTC Wildfire touch screen frozen
You can try 2 things:
    1)Soft reset - clears memory and restarts program
    2)Hard reset - deletes all saved data and settings
    Soft reset
      -Locate reset button to right of USB port on bottom of phone
      -Press reset button with stylus
      -Wait
      Hard reset
        -Press and hold both talk and end buttons
        -Press reset button with stylus while holding talk and end buttons.
        -Release talk and end buttons and press enter
How to Troubleshoot Frozen HTC Touch
Aug 29, 2017 | iPhone Apps
Z22 palm handheld touchscreen won't respond - i've done soft reset -- several times -- used the 5 way to bring up the touchscreen -- tapped and nothing happened.
Hi, Try doing a hard reset to see if this will correct the problem.
Hold down the power button and at the same time use the tip of your stylus or any other non sharp item and press the inside the reset hole on the back of your palm.
When you see the Palm power logo appear you can let go of the power button and also the one on the back of you unit.
It will display a message asking if you want to do a hard reset and that it will erase all your data. select yes by hitting the up part of your 5 way button on the bottom of your unit. This is the one you use to navigate around your palm screen. After it resets you wil then be prompted to reset the screen by tapping the targets. If it works great. If not then you have something wrong that needs to be looked at. Before you send it in go to:
www.palm.com.
Select pda and then your model. From there go to the support screen and do a live chat. This is free and they may be able to live you some help. Best wishes.
Sep 19, 2009 | Palm Z22 Handheld
My Z22 touchscreen does not respond to the stylus
This shows the OS is corrupted. Try to flash the device
Jul 25, 2009 | Palm Z22 Handheld
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
Touch screen is completely not working ATT 8525.
contact the manufacturer or your cell phone provider about this error. They might of created a firm ware upgrade to provide a solution to this error.
Let us know if it continues or they do not have anything on file.
Thanks for your time!
Sep 08, 2008 | Cingular Wireless Cingular 8525 Smartphone
Touchscreen after SDIO update
See other touchscreen designation forums.
Aug 01, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Dopod 838 pro touchscreen not working
Have you tried a hard reset?
(Hold in the power button why pressing the stylus in the reset button on the bottom of the phone)
Jan 29, 2008 | HTC TyTN Smartphone
Palm z22 touch screen screwed up
clean the touch screen and go under the edges w/ a bankcard to remove any dirt.
then do a hard reset -- worked for my z22
c boekema
Jan 14, 2008 | Palm Z22 Handheld
Touchscreen keyboard
Sounds like a problem with the digitizer. Mine started out like this and got worse. I have owned my Palm for about 1-1/2 years and at least twice I had to do the following as my touch screen eventually quit working and I couldn't get the digitizer to fix it either. Below is what I have found that works and so far is the only solution. I think this is a bug in the system, but PALM has not yet posted any info or a patch to correct it. Unfortunately, this will erase all your data so be sure to back it up first.
Sounds like the digitizer is so far off that the input won't align correctly. This would, most likely, be confirmed if you get any response when you tap the touchscreen (moving cursor, beeping, etc). You'll need to try a soft reset using the little reset tool in the end of your stylus, or a paperclip if you don't have it. Press and hold the reset button inside the unit (located in the back panel) for a few seconds until it chimes and you see the Palm logo. Then try the Digitizer again to calibrate.
Now, if that doesn't work, you may need to factory reset the device. THAT MEANS YOU LOSE ALL YOUR DATA, so do whatever you can to get it backed up. You simply hold the reset, then press and hold the power button for several seconds. Instead of the standard Palm logo you'll see a prompt asking you to press up on the touchpad, on the front of the unit, to reset it to factory default. It will then run you through the initial setup routine to set the date, time and finally calibrate the Digitizer.
Dec 10, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten E2 Handheld Logo
151 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
