Question about Kenmore Elite 45986 Front Load Washer
How do you restart washing machine?
I started washer with the water line shut off. Now the panel is flashing the time left and the machine is making noise but nothing is happening. I pulled the power plug and turned the water line on but I can't get the washer to do anything. Is there a way to reboot computer inside this machine?
  • 121 Answers
Plug in power and turn program button at off(0),then open water and choose a program
Posted on Feb 17, 2009
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
I am shutting down my camp for the winter. is
make sure to drain and disconnect the water lines, also make sure that there is no water left in the drum, other than that- that's about all you can do
Nov 04, 2009 | Asko W6021 Front Load Washer
My machine is not aggetating it just keeps filling with water
if the water is not over flowing on the floor.make sure your washer is off,then pull the drain hose up to the level of the back control panel you should here water flowing out once this stops.keep the hose up for aminute and restart your waher and it should fill up to the proper level and shut off and start washing
Sep 26, 2009 | Maytag Legacy Series Top Load Washer
Water will not stop filling
It appears that you might have inadvertantly disconnected the pressure switch when you where replacing the main timer control.
You'll need to open up the control panel again to check all connections and take a look at the 4-way pressure switch on the left side of the control panel, when looking at the front of the washer.
Here's a line drawing that you can refer to so you can locate the pressure switch and make sure the connections are firmly pushed onto it.
http://www.fixya.com/PostAnswer.aspx?thid=2993479&prdid=46860&ref=unsl
The pressure switch controls the amount of water that is allowed into the washer for the various wash water levels you select. Without a correctly functioning switch, the water inlet valve will not shut off and will overflow the washer given enough time on the fill portion at the start of the wash cycle.
Be sure to disconnect/unplug the washer from the power outlet before taking apart the control panel and doing any work.
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Paused washer will not restart
check that machine has not gone onto time delay , re-set if it has
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer Pauses and Shuts down Repeatedly
Check the cold water line into the unit. Remove the hose from the washer and clean the screen. flush the line while it is disconnected into a bucket or small garbage can. Your washer wont advance without a fill and most fills/rinses are with cold water
Dec 01, 2008 | Frigidaire Affinity ATF7000E Front Load...
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
48 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
