Question about Pitney Bowes 9920 Plain Paper Fax
Pitney Bowe 9910 Fax Machine - paper jam
We can not clear a paper jam from the fax machine.
It appears the paper will not continue to feed through the toner area.
Could be the problem be in the roller on the door cover?
Any help would be appreciated.
2 Suggested Answers
  • 47 Answers
SOURCE: Paper jam on Pitney Bowes 9910
try a new toner, if not it could be fuser
Posted on Jul 10, 2010
Display says line error and print out says jam
• Check the connection. The cord from the TEL.LINE jack to the wall jack should be no longer than
six feet.
• Make sure there are no modem devices sharing the same telephone line.
• Check with the other party to make sure their fax machine is functioning properly.
• Have your telephone line checked for line noise.
• Try connecting the fax machine to a different telephone line.
• If the problem still occurs, your fax machine may need service.
Clearing a jammed document
If the original document doesn't feed properly during transmission or copying,
or DOCUMENT JAMMED appears in the display, first try pressing start/memory . If
the document doesn't feed out, remove it as explained below.
Important:
Do not try to remove a jammed document without releasing it as explained
below. This may damage the feeder mechanism.
Jan 17, 2011 | Sharp UX A255 Plain Paper Thermal transfer...
How do you set the time on a 9910 PB Fax?
You need to go into Set Mode and User Parameters
To do this press Function key and 7 to get Set Mode
Then press 1 for User Parameters and set, the first option is to set date and time, use the number pad to do this.
Nov 03, 2010 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowe 9920, incoming faxes have black vertical columns on each side, with white or normal print in center.
Have you changed the toner cartridge? Often the disposal part of the image unit gets full and leaks out when the cartridge is reaching the end of its toner supply. This will leave black messy streaks on paper, and also make a mess inside the machine. Look inside the machine, if there is a mess, it is the cartridge.
Jan 13, 2010 | Pitney Bowes Office Equipment & Supplies
Fax machine is saying paper jam but does not appear to have paper jam
I have been having the same problem with my fax.
If you switch off the fax machine for 30min then switch it back on again the fax will resets its self and this should clear the error.
Martin
Jul 14, 2009 | Samsung Office Equipment & Supplies
I have a paper jam on my Pitney Bowes 1630. The
Good Luck, When the paper is stuck in the back, it is in the fuser and you may be able to get the paper out, but probably the drive for the fuser is messed up, which caused the jam in the 1st place, if you get the paper out, the next one through will probably jam up again. Technicians usually just replace the fuser. Oce is the repair entity for these machines now. 1 800 2423 5556
Jun 09, 2009 | Pitney Bowes 9920 Plain Paper Fax
Feb 17, 2009 | Pitney Bowes 9920 Plain Paper Fax
Our Pitney Bowes 1810 Folding Machine hums & the document dial for the folding style does not move! Help!
Problem is not fixed. It does not involve a fax machine, it involves a Pitney Bowes 1810 document folding machine. Not interested in paying for "service" - it appears as though your service would be of any help.
Thank you
Jan 26, 2009 | Office Equipment & Supplies
XEROX TELECOPIER 7024
Does it say clear jam immediatly or does it start to run then declare a jam?
If it starts then tells you to clear a jam and no paper is in the machine, your feed rollers are shot. Smooth like trying to drive a car on ice.
If it says that all the time, no attempt to feed then you have a sensor either dirty, knocked out of place or something stuck on a sensor.
Either in the paper path or in the scanner.
Mar 26, 2008 | Office Equipment & Supplies
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Paper jam
There is either a jam in there somewhere where you can't see it, or if it clears, the feed roller is not feeding the paper, in either case you probably need a tech.
Jan 07, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Pitney Bowes 9920 Plain Paper Fax Logo
154 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Victorman
Victorman
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
