Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Air and heat have both been running on Hunter 44155C
We heat with gas so when I got my December electric bill, it was outrageous. We had the Hunter 44155C digital thermostat installed in late summer by a licensed electrician we had used for years. At first, I had problems programming it. I had it set on 72 and it was 79 in our house. We were burning up in August. I thought I was programming it wrong. So we dealt with it for a few weeks. Then the weather cooled and I didn't notice any problems with the temperature. When I changed it to heat, we had no problem heating the house. Only when we received our December electric bill, did I start to be concerned. Our electric rates had gone up, so ... Then after 3 months of outrageous electric bills, I went to our electric office and had them come and they discovered that our air conditioning AND our heat were both running at the same time. And they had been since we had the Hunter 44155C
digital thermostat installed. That explained why it was so hot at first and why our electric bills were so high. Our compressor had been running at the same time as our heat. We had the thermostat removed and replaced it with our old one. Everything seems to be back to normal now. Has anyone else had this problem? I was wondering if there had been any recalls on this or if I just got a bum one?
  • durcholz Feb 25, 2009
    I have not checked to see if my A/C and heat were running at the same time. My eletric bill are like $70.00 higher than the previous years. My gas bill is like $125.00 higher as well. I am just going to install a honeywell thermostat.
  • jeffemmert Apr 05, 2009
    I followed those instructions to the letter, replacing those old gold Honeywell dials with the Hunter 4415Cs. We both have gas furnaces and electric air conditioners. It seems to work fine at the first house, but at the other, the air conditioner also comes on. For now, I switch off the a/c using the circuit breaker.
  • 2,976 Answers
There should be a switch on the thermostat.
And another switch
Normally, you just set it for heat or AC and set the fan for auto. If it isn't wired correctly, the switches won't make any difference. It will either run all of the time or not at all.
Posted on Feb 17, 2009
I have old Honeywell with 7 wires W2, L, B, G, R, Y and E. Now I have bought Hunter 44155c with six terminals: G, RC, RH, Y/O, W/B and Y1. How can I connect them? Thank you so much for your help!
You need a 2 heat, 1 cool, heat-pump thermostat. W2 is the heat from the heat-pump unit outside, E is the emergency heat inside the house (usually electric), and on the new thermostat you just have the one W terminal for heat. You can jumper the two wires together (W2 and E from the old thermostat), but you will get both heats all the time when its being called for. Since you may have powered heating instead of powered cooling, I would try to get a thermostat that matches up better, otherwise, you might run into more problems than just the terminals, like rewiring the heat pump and furnace/air handler to accommodate the new thermostat. Hope this helps, and if you still have problems afterward, be sure to explain which wires were already hooked up to which terminals and so forth so we can have a little better idea whats going on, sometimes it can get confusing without being there. Good luck and hope everything works out for you!
Jun 19, 2011 | Heating & Cooling
Cannot get Hunter stat 44155c that is connected to a Rheem 1210b to shut off after the stat reaches the set temp. How is an original 7 wire connected to the Hunter stat?
y is to condensor contactor wire
c is common
r is power
w/w1 heat strips
o/b reversing valve
e/w2/aux heat strip also
g is blower
For a rheem unit, make sure reversing vavle is set for "B" not O.
Blower may run for up to 120 seconds after shut off. My experience with hunter stats are not good (even out of box). Recommend honeywell tsat.
Apr 05, 2011 | Heating & Cooling
I puchased 5 year old home back in July and up until the last few months my electric bill has been any where from 800kwh to 1500kwh. It jumped in December to 3880 and 4500 in January. My home is 2400sq,...
You will need to have a HVAC tech to check your Heat Pump..... It is not working or not heating properly....And you are heating the house with the electric heat strips which will make your electric bill double The electric heat strips are there as back up if the heat pump is not working or keeping up with the heating demand.
Feb 12, 2011 | Heating & Cooling
I bought a Hunter 44155C programmable thermostat to replace my Carrier non-programmable one. The wiring on the carrier is: W- white wire O- no wire G- green wire R- red wire C- blue wire Y- yellow...
Hello,You need RH/RCjumper together=red wire...C=blue wire...G=green wire...Y=yellow wire...W=white wire...O/B unused for reversing valve for heat pump.Hope that helps. : )
Nov 10, 2010 | Hunter Heating & Cooling
Wiring mdel 44155c unable to wire properly
what wire goes where on new thermostat my wire on old thermostat are red, white, green, and blue ro could u please tell where to connect them on this new thermstat.
Nov 02, 2010 | Hunter 30124 Air Conditioner
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
746 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
