Question about Sony CFD-S300 Radio/Cassette/CD Boombox
No power to unit. All functions dead.
I have used this unit very little and when I turned it on the other day nothing happened. I checked my 120 Volt source and the power cord and I had power to unit. I dismanteled covers to see if there was a fuse but could not find any. The unit had not been used for approx. 4 months prior to turning it on and it had always functioned properly before.
The product is out of warranty and Sony has a program of replacement with a refurbished unit which actually cost more then I can by a new unit for.
I would appreciate any help in troubleshooting the problem.
  • perry0024 Feb 18, 2009
    Thank-you Jee for your help. I will check it out this weekend. I forgot to mention that it does'nt work on batteries either. Do you think it could still be the power transformer.
  • 10,594 Answers
Please check AC transformer in CFD-S300 that seems fried (open)
if it found bad, you can buy it under following part number..
1-435-917-11 TRANSFORMER, POWER (US,CND)
It is available in Part Store.
Posted on Feb 17, 2009
  • Shahid Electronics
    Shahid Electronics Feb 18, 2009
    Now senerio is changed as you mentioned it does not function with batteries.
    Please check does unit has power supply volts input from power supply board.
    Now service manual, schematics would be helpful to find what is wrong with this tape.
LG ldg3016st has no power on main control panel
Did you have any power surges in the house? Any thunder storms?? even if you are not using a microwave, but it is plugged in , you see the clock?? That means it is getting power and running the clock so while you may not be cooking in it, it is actually using power to run the clock functions. So, if there was a power surge, it damages a part on the main board called the Low voltage transformer. It takes the 120 volts from the wall and drops it down to the voltages the board needs to operate, sometimes 5,12 24 or maybe 30 volts. If the primnary winding gets damaged from a surge of some sort. it will no longer light up if that small transformer was damaged. That can happen without even blowing the fuse as the small wires in the transformer were never meant to carry the 15 or 20 amps the fuse is rated at. So the transformer goes bad and the unit is dead but no blown fuse. Have to check the primary winding of the low volt transformer to see if it has continuity. If not, will need new main circuit board. Sorry But $$$$$
Sep 16, 2017 | LG Microwave Ovens
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
While running in a screw to install a new electrical outlet cover, the outlet made a small pop and the lights flickered but immediately came back on. I plugged in the unit to see if it worked and nothing...
You say the unit is 220 volt, but the plug you installed has a white wire which is normally on a 120 volt outlet. A 220 volt outlet would have 2 black wires and ground. If you do have 220 there, and the reset does no good, I've seen those resets(they are basically built in GFI) blow out and had to bypass/put different chord on. there are fuses on the control board but I would check that last
Jun 24, 2011 | Frigidaire FAS257S2A WallWindow Air...
Our son bought a ARC-125 Whyniter Portable Air Conditioner the summer of 2009 - he accidentally plugged it into a 220V outlet and evidentally fried the components. I would imagine it's not fixable but...
Hi Karen, and yes more then likely a lot of the controls were cooked. It doesn't take long with that high of voltage to take out motors, burn the insulation off of wiring and so on. Depending on how long it was plugged in and how long that much voltage had run through it, try plugging it into a 120 volt receptacle and see what happens. I would do this before any thing else. I have seen this happen on other units and just melt the 120 volt power cord. So, plug it in to see what happens, and if it seems to run good, you may have turned it off in time. If nothing happens, and this unit cost you a lot off $$$, it may not hurt to take it in to a appliance repair shop and get an estimate. If you smelled a lot of electrical burning, I would look at where the power cord comes and ties in, that may be as far as it got and check it if you have someone that is able to do this. But, my guess it is probably dead. I am sorry this happened to you. Please don't forget to rate my post as I know you will be kind.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Sep 24, 2010 | Whynter ARC12S Air Conditioner
I think my HP Pav powersupply is dead. When I plug it in and try to turn it on, nothing happens to the HD and computer except a green light flashes on the back of the power supply. It is a Bestec...
all atx powersupplies are generic-it dous not really matter what computer it comes from unless its a high end pc requiring loads of power-if your machine is intel you may need a supply with an extra twelve volt lead(two yellow and two black leads in a little block)-but for that pc i would just harvest a powerpack out of a dead machine
Feb 25, 2010 | Compaq Computers & Internet
Mr. Heater Natural Gas Garage Heater - 45,000 BTU. Power 120 volt and 24 volt good. Thermostat calling for heat, but nothing happening??
Check for a fuse either in-line or on the circuit board. There should be 24 volts going to the thermostat. If not, you have either a bad transformer or a bad thermostat wire. Jump out the terminals that the thermostat wires are connected to. This should force the unit to fire. If not, bad circuit board.
Dec 23, 2009 | Mr. Heater Natural Gas Garage Heater -...
My acer aspire 5920 is completley dead it will not turn on with a fully charged battery which was charged up using a second 5920, it will not turn on with a working power supply either. I have completly...
Might your switch be non-functioning? Can you check that independently?
Otherwise, sounds to me like you did eveything.
Same thing happened to me with my dog once. I let him out and that was it! :-)
Oct 09, 2009 | Acer Aspire 5920-6727 Notebook
Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
Mar 02, 2008 | Yamaha RX-V995 Receiver
Power Source
Are you certain the polarity of the connections to the TV are correct? If you connected them in reverse you may have damaged the TV. If there's a fuse in line check that too. BMW
Jun 01, 2006 | Ktv 9BNC 9 in. Television
Sony CFD-S300 Radio/Cassette/CD Boombox Logo
234 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
