Question about Thermador PC366BS Stainless Steel Gas Cooktop
Stainless Steel Cooktop - Remove Sealant Spray
When our tile backsplash was sprayed with a sealant, the workman got the spray on the stainless steel cooktop. What is the bes way to remove this dried on spray? I tried stainless steel cleaner with papertowel and that did nothing. I am afraid to scrub with anything abraisive as I do not want to scratch the ss surface. Please advise.
  • May 11, 2010
    hi my name is mark, is this cooktop brushed stainless. if it is try a green scotchbrite pad. make sure you scrub with the brushed stainless not against it. or try ac acatone with a soft cloth. be careful acatone is very flammable then use a stainless polish.
  • 30 Answers
Easy peasy.
Use Bar Keeper's Friend and a damp sponge.
Rinse.
Wipe with mineral oil (in most stainless steel ceaners)
Good as new.
Posted on Sep 30, 2009
  • 91 Answers
Try paint thinners , but before you do any thing you need to call the workman to see what brand of glue he has used.or to come out and clean it off for you or to see if thinners will work , it normally does but when i do resturant kichens out any spillages of glue is removed straight away.you will need to use polish cleaner after the thinners to stop any further marks appearing
Posted on Aug 31, 2009
4 Suggested Answers
  • 530 Answers
SOURCE: Trying to remove stains around the gas unit where temp is the hottest.
have you tried cooktop cleaner? this seams to work pretty good at getting stains out of stainless steal. (You know...cooktop cleaner is really just car wax if you had some try this on a little area and see how it works and if you like the results...there you go.) let me know what you think. But like i said always do a test point before doing the whole surface.
Posted on Apr 23, 2009
projdoc
  • 2237 Answers
SOURCE: discoloration around burners
the discoloration is from the heat. you can buy a stainless steel cleaner or use simple green for the grease.
Posted on Jul 20, 2009
SOURCE: How to clean the stainless steel stove top
Someone else suggested Easy Off Oven Cleaner (I used fume free). I just finished using the Easy Off (make sure you cover the electronic ignition) with Q-Tips and my top looks almost as clean as when I first got it.
Posted on Sep 07, 2009
Fix scratches on stainless steel appliance
The professionals in order to remove the scratches from st. steel they use special metal wire meshes like soft scotch bride attached on special rotary milling machine. They brush it in the direction of the grooves on the st. steel surface. They start with a hard brush and they reduce the strength until they finalise it as the original finish. If it a brush surface this is more easy than a polished mirror surface. These procedure need experience and care so you will not end up with more damage than the original one.
Dec 29, 2012 | Electrolux 30" Electric Hybrid...
How can I clean the black cooktop grids?
put in kitchen sink with hot hot water over night, with dish washing liquid. preferbly when kitchen is not being used. (After dinner time) drain then spray with mr muscle oven cleaner give it about an hour, then scrub the **** out of them with a stainless steel goldilocks. Rinse then soak in hot water again for 20 minutes then drip dry. After use when cooking always clean any mess left behind. Wipe down so it is easier for you to wash when needed.
Sep 06, 2012 | Maytag MGC5430BDS Gas Cooktop
After spraying stainless steel cleaner on the cooktop, with the knobs removed, the igniter won't stop ticking as if it's trying to ignite. All the knobs are securely in the off position. Could this be...
Yes, the moisture is probably the problem...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 21, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
How to remove brown scorch mark on stainless steel cooktop cover
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Mar 26, 2010 | Jenn-Air JGC8536 Gas Cooktop
The stainless steel rings on my cooktop are already getting burn stains. How do I clean them without discoloring the rings?
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jun 17, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Bleach stains on stainless steel triming on cooktop
DeBruce Polish is perfect in the RESTORATION of STAINLESS STEEL, it will even remove rust from stainless and polished chrome.
Check them out- you will be glad you did!
debrucepolish.com
Note: see DeBruce Method on "You Tube"brucedebruce09
Apr 01, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
Mar 20, 2008 | Thermador PSC364GDZS Gas Cooktop
Stains from cleaning products?
Bosch (BSH appliance care) do a stainless steel conditioner you could try. I think its called Starglanz.
Nov 05, 2007 | Bosch 36 in. NGT 935 Gas Cooktop
Thermador PC366BS Stainless Steel Gas Cooktop Logo
181 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
