2004 Dodge Caravan Logo
WILLIAM THOMAS MCGEE Posted on Feb 24, 2013
My 2004 Dodge Caravan Tachometer stopped working
After getting a jump start, my Tachometer and heater blower stopped working. What could be the problem with the Tachometer?
Anonymous
Level 1:
New Friend:
  • Contributor 47 Answers
  • Posted on Mar 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
47
Questions
Helped
25184
Points
82
Have you checked the fuses? it more than likely blew a fuse if not then maybe fried wiring from jump start.
4 Related Answers
Anonymous
  • Posted on Dec 25, 2008
SOURCE: air conditioner blower motor resister on dodge grand caravan
in my 2004 grand caravan it's behind the glove box and left of the blower motor. disconnect the wires first then remove the 2 screws to pull out the resistor unit. First make sure you have removed the negative of your batterie. I had the same pm that prevented the blower motor to operate in any speed. I hope this will help
Anonymous
  • Posted on Feb 01, 2009
SOURCE: locating heater blower motor resistor
the resistor is behind your glove box. open the box and push in the sides to release it and let it hang down...the resistor is right there. I didn't try to replace it, a friend did it, but the part was under $20.
Anonymous
  • 1985 Answers
  • Posted on Nov 23, 2009
SOURCE: 2004 Grand Caravan Front blower will not come on.
Check owners manual for location of heater blower motor front,check with a test light,if it's good locate blower motor under glove box and test the two wires for power when switch is turned on,if power is present motor needs changed.if no power check blower motor resister.
Curt Downs
  • 1779 Answers
  • Posted on Dec 05, 2009
SOURCE: 2001 Dodge Caravan heater blows cold air when stopped
Have you checked the coolant level? What you describe is exactly what happens if the coolant level is low. When stopped at idle, hot coolant is not circulating through the heater core, so no heat. As the engine increases in rpm's when you pull away from the light, the water pump is spinning quicker, and some coolant is making it to the heater core. So check the level, and if it is low, keep an eye on it to see if it drops again. That of course indicates a leak somewhere. Get it fixed, as overheating the engine leads to costly repairs and worse case a new engine. Let me know how you make out with this.
Testimonial: "Thanks Curt! You were right ON!"
My heat stop working i ben looking for the fusebox wher is it
is it not working in front heater or rear heater? if front heater check under hood blower motor resistor should be changed , cause i had same problem with it , or u should change fan heater. check it under hood , have nice day.
1helpful
2answers
The front heater/air conditioner blower stopped
First check the voltage at the front blower moter. If it has voltage then it may just need a new motor.
2004 Dodge Caravan with 3.3 ltr eng. Won't start,
This sounds like a classic bad connection either at the battery or engine ground. Check and recheck all your connections and be sure they are clean and tight.
Front heater not blowing
Check the front blower to make sure it is working.
3helpful
01 dodge caravan has heater blower that will not work until the van is up to highway speed.
Does the blower actually start working at speed, or are you merely getting air flow due to your forward motion? Check the fuse for the blower, and the switch. Use a test light to see if you are getting power to the blower motor. Is the ground connection for the motor clean and tight? If you have power, the blower motor may be defective, or something blocking it from spinning.
1helpful
2004 dodge neon speedometer stopped working
Try giving it a good rap on dash above speedo, see what happens, and get back to me, it may have same problem as my old 95' neon did.
Heater fan stopped working
did he check the blower resister tell him to jump the fan to see if it is bad if he jumps it and it does not come on it is bad
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
