Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
No reception as a portable unit
Works great in cradle but will not receive reception even with headphones or lipstick. Is the internal antenna fried? Can it be fixed? Should I bother?
    Problem Solver:
  • 13 Answers
My experience with the XM2Go is that it never really works well on the portable antenna -- in my case not a complete failure, but that might be because I am in an urban area there are ground transmitters in addition to satellite reception. But any movement disrupts the signal Here's the solution - record some music on myxm (up to 5 hours) while docked, and play that music when not docked to an antenna.
Posted on Feb 28, 2009
I fitted a Peak dvb-t digital tv usb stick with an ariel included and it doesnt pick up any channels. if i fit an internal tv card will that work instead please?
IN GENERAL these decives don't have decent reception when working in side and with the internal ariel. If you can use an external roof fitted ariel you will get better recpetion. I even had a dedicated portable tv that didn't receive all channels, in France, due to the inferior internal antenna.
Jul 05, 2011 | Computers & Internet
My stiletto does not get a signal. It comes in for up to 10 seconds at a time and then nothing, searching. I walked to the top of San Bruno Mountain overlooking San Francisco with no improvement in...
Does it get a solid signal when its in a docking station? Its likely that the internal antenna on the unit is disconnected. Antenna headphones would correct the issue, though they are not very durable at all. I know that our repair guy is able to fix the internal antenna, but I would ensure that is the issue first. Try plugging it into a home dock, car kit, or boombox to see if it works through one of those antennas.
May 26, 2011 | Sirius Stiletto 2 Portable Satellite Radio...
I have a problum with my nuvi 610/660 not recieving satellite signals?
I have repaired literally hundreds of the 6xx series units with reception issues. In most cases, the problem is caused by a defective part on the GPS receiver board, located in the flip-up GPS/Antenna assembly.
In many cases, reception can be restored by connecting an external antenna to the unit. The defective part causes the unit to only look for signals at the external antenna port. In some cases, the part may prevent reception with both the internal or external antenna. In this case, the part must be replaced. Firmware upgrades will NOT fix this problem. It is a hardware problem caused by an electrostatic discharge.
For more information about this problem and how to have it repaired, please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
SHARCNET-USA
Nov 04, 2010 | Garmin Nuvi 660 GPS Receiver
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
Poor reception on atsc portable tv
an external or outside antenna will improve the amount of stations picked up and maybe a amplified antenna will help
but the boxes they sell seem to do better in reception even with only a rabbit ear antenna.
I use a box on my 32in LCD because the internal tuner just does not get all the channels without having to get up and move the antenna and the outside antenna , well I'm not going to go out there to move it all the time , and the amplified antenna I still have to keep getting up to move the antenna
so in all the box( "zenith","digital stream"are good , have yet to test others) works the best in recieving the digital channels without much worry of the antenna
Mar 13, 2009 | RCA 9V345T 9 in. Portable Television
Stiletto 2 Internal Antenna broken - Am I F'ed or what?
you can try to open it and resolder is really easy but you have to be carefull when you take it a part there is many small resistors and capasitors near the antena and you will need a scope to see the wires and to solder i fixt my like that and it works fine
Jan 12, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
Acquiring signal
This unit looses reception all of the time even with the antenna headphones placed right next to my cars antenna.
You need the car or home kit or else you will suffer many drop outs "aquiring signal".
Dec 17, 2008 | Sirius Hoods Stiletto SL100-PK1 Satellite...
Antenna
Wear the antenna headphones around your neck and use ear buds. Works like a charm!
Jun 04, 2008 | Delphi SKYFi3 Satellite Radio Receiver
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
Internal Antenna not working anymore
if you do a search at pdaphonehome.com a guy has replaced his antenna and provided step by step instructions for how to do it yourself with pictures. I don't know if frying it can make sure getting a new antenna will fix that but thats something you can try before replacing.
May 12, 2007 | Samsung SCH-i730 Pocket PC
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
155 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
