Question about Kenwood KVT-512 Car DVD Player
Kenwood KVT512 - Intermittent Lock Up
I have a refurb KVT512 in my car. On two occassions I have had it lock up on me. Both times it was working fine when I got out of the car, and then when I get back in it doesn't power on. If I press the reset button it come to life, but then I have to reset some (not all) of my settings. Since it is a refurb'd unit, I can't help but wonder if it was RMA'd for this, and maybe the factory just didn't get it to act up, so they turned it back out.
Any help would be appreciated!
-Jim
  • 1 more comment
  • Jim Kramer Feb 18, 2009
    I called Kenwood Tech Support, and they suggested I update the firmware on the unit. I was runnig version 1.4.0, and the latest version is 1.5.1
    I have applied the update, now I jut need to wait to see if it happens again.
    -JK
  • Jim Kramer Feb 27, 2009
    so far, the firmware upgrade seems to have fixed the issue. It has not locked up in the last 10 days.
    -Jim
  • Jim Kramer Apr 21, 2009
    the firmware upgrade did indeed fix the issue. It never hapenned again!!!
5 Suggested Answers
SOURCE: kenwood kvt817dvd powers up after reset but cuts out after src
I removed my brain from beneath my seat and exposed all wires and connections. I have found that on mine (kvt-815) there were two pinched wires- 1 for a speaker and the other the remote wire. I respliced these sections and tested my radio again. It appears to be working now and stays on again. I'm guessing one of the wires must have been touching something metal under the seat (seat frame) and grounding out. If the unit doesn't power on at all, check the fuse first. Otherwise, I would  inspect every wire like I did and maybe you'll find a pinched (grounded) wire. Maybe I just got lucky... but at least it's working again and I don't have to replace the brain! Hope this helps.
Posted on Mar 30, 2009
SOURCE: kenwood kvt512 code
forgot my code how can i reset it
Posted on May 16, 2009
SOURCE: kenwood kvt512- IPOD hookup not working...wont work in usb either
kenwood.com/cs/ce/mm/firmware/2008/eng.html
this is the firmware update I used to get my Ipod to work on my kvt 512
sodeep
  • 3267 Answers
SOURCE: touch screen doesn't work.
The password can be entered by setting the arrow buttons, if u know the password, or get kenwood to give their default password and check that the touch screen is not getting grounded, 'cos that's when it goes apparently, dead...sodeep
Posted on Jun 23, 2009
kenw392
  • 2226 Answers
SOURCE: Lost or misplaced plug for
try pacparts.com.
Posted on Jun 07, 2011
My kenwood ddx7050 doulble din got lock cant enter in
The manual should have a way to hard reset the unit and completely reset it so the lock will be removed
May 03, 2011 | Kenwood DDX-6019 Car DVD Player
Touch screen doesn't work. It is a kenwood KVT512 DVD/CD player with a 7" touch screen. at first, I couldnt get any of the buttons to work, not even the power button to turn the unit off, so i pushed the...
Jun 23, 2009 | Kenwood KVT-512 Car DVD Player
Just purchased a brand new Kenwood KVT512 and the ip300v interface cable. i can play music from my i pod but i dont have any interface, it basically just acts as an audio input rather then linking to the...
Did you buy the adapter for the ipod and are not just hooking it up directly through usb. It sounds like their may not be the correct adapter attached. The adapter comes with plug for the ipod on one end, and a usb, audio, and video plug on the other end. Without that you will not see anything on the screen due to not having the correct cable to display the video portion.
Feb 24, 2009 | Kenwood KVT-512 Car DVD Player
Monitor says protect
my kvt512 shows PROTECT on the moniter, how do fix it?
Feb 15, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood kvt512 code
Jan 27, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 Car DVD Player Logo
215 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
