Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
When I start my washing machine it is just draining continuosly.
Machine continuously draining needs the drai pipe lower than the machine, push it further into the outlet drain. from Alan
Posted on Feb 17, 2009
I have daewoo washing machine When i start it to fill.the water its continuosly draining its not filling wat to do
A soliniod must be jammed open with crud ,try putting a good cleaner through the machine clamping off the drain hose.
Mar 29, 2016 | Daewoo Washing Machines
Why lg 7.2 kg washing machine drain continuosly
I think it`s stops draining only when all the water is away. Maybe a drainage problem or a blocked filter?
Dec 18, 2015 | LG Washing Machines
My washing maching is reading E20 and it is not washing. it seems to stop after a few minutes of washing and then it will read E20 and just continuosly beep
Hello.
Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
Blocked Pump
One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
Drain Hose
If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
Oversudsing
If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
Pressure Switch or Control Boar
The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
Thanks.
Nov 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
We continuosly get an LD code on our Oasis Washer. Hoses are fine and have ran it through the clean cycle several times. any suggestions
LD means long drain ( time ) and is usually attributtable to either a bad water pump, clogged water pump or clogged hose from tub to pump or pump to drain.
Jun 01, 2011 | Washing Machines
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
Sometimes my new machine will not fill with water
make sure that your drain hose is coming up ( 90 degrees ) from the base of the machine. and then drains near or close to the height of the machine. the drain hose at least needs to be at a 45 degree angle to fill properly otherwise it will continuosly drain. hope this helps.
Oct 18, 2009 | Washing Machines
Wont spin...continuosly beeps
Does it wash? If it washes and then will not spin and drain it is more than likely the pump that needs replaced.
Jun 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't drain
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Aug 05, 2008 | GE Energy Star WCVH6260F Front Load Washer
My washer won't stop draing as it fills
Does the washer makes a full cycle properly and only problem is water's constinously draining ? If this is the phenomena, verify that the pipe discharged to the drain hose (the pipe that water going out from the machine)is at washer height up to one foot higher. Goog luck !
May 25, 2006 | GE WBB4500EWW Top Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
