HDMI to DVI-D conversion problem. Not in compliance?
I own an Akai PDP5006H Plasma TV with DVI-D input connection. It does not have a HDMI input. My cable box and new DVD player only have HDMI and when I bought a converter connection from HDMI to DVI-D, it works for about 2 seconds then it says ''Not compliant''. This happens with both my cable box and the DVD player. Do you know the solution
  • 23 Answers
It souunds like te TV is having problems with the streaming data being applied Most plasmas with DVI connections were actually designed for PC type input signals  Unfortunately the TV's input may not be able to stand up to the stream of signal the DVD or cable box wants to display. You can try and lower the output of both devices to 720P Good luck to you
Posted on Feb 17, 2009
***Need Help Connecting HP Pavilion dv6500 (running Win Vista SP1) To Panasonic Plasma!!
No. It is not going to work.
VGA is an Analog signal. HDMI is a digital signal, that is why you need the box, it converts analog to digital.
You can get VGA to DVI and DVI to HDMI convertors because DVI is capable of using both - depending on the type of DVI you have.
What is the difference between DVI and DVI NVIDIA
HDMI Wikipedia the free encyclopedia
Video Graphics Array
Mar 29, 2017 | Computers & Internet
Connecting amilo 2727 to plasma tv
Well depending on what output your laptop has and what input your TV has you will have to find a cable that accommodates both.
Common laptop outputs: VGA, DVI, HDMI
Common TV inputs: RGB, HDMI, VGA
Jan 23, 2013 | Computers & Internet
I have an akai pdp4298ed plasma tv the DVI and PC inputs are not working.
The Akai is Samsung brand--have you when using that input that does not work gone into the menu and "selected" it and or highlighted it?
Apr 14, 2012 | Akai PDP4294 42 in. EDTV-Ready Plasma...
I have a Lenovo Thinkpad T61p and I want to connect it to my Samsung 43" Plasma TV. My computer only has a VGA output and the TV only has an HDMI input. How do I connect them? I tried a VGA to HDMI...
You need an adapter and the bestis to approach the nearest computer accessories store where such ones are available to which the conversion cord you bought can be used.
Please check this interesting utube presentation;
Oct 01, 2011 | Samsung 43 PN43D450A2D Plasma TV
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
What cable do i need to connect my laptop to my Sanyo DP50740?
Hello jaygee7414,
Sanyo DP50747 not support for D sub conection (PC in).
To connect PC in, you can use DVI or HDMI input.
Some Laptops already have HDMI or DVI out put. Like HP mini, sony vaio.
Or you can use s-video input.
Thanks.
Mar 21, 2011 | Sanyo DP50747 50 in. Plasma TV
My tv does not have an hdmi port. I have a device I'd like to import (Apple TV) I'd like to connect. It has an hdmi input for connection to the TV. Is there something I can do to be able to connect to a...
There are adaptors available to convert HDMI signal to other standards. You will lose quality in picture and sound but you can get HDMI to RCA converter. If your TV has a DVI is still a digital input so will yield better quality.
Jan 14, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
Sansui 42'' HDMI problem
howto get the hdmi signal thro hdmi to dvi cable in plasma pdp42 sansui tv in dvi input
May 03, 2009 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
Televison & Video Logo
894 people viewed this question
Top Televison & Video Experts
