Question about Exercise & Fitness
TUNTURI 620p TREADMILL displays 51, or S1 WHEN TURNED ON , AND WILL NOT OPERATE. PLEASE SEND ANY INFORMATION TO HELP SOLVE THIS PROBLEM.
  • Anonymous Apr 14, 2009
    i was working on the treadmill last night and when i went to use it this morning it showed a 51
Solution:
press and HOLD the button that says display above it and Reset below it untill you see the normal start up Screen and yoru good to go!
Posted on Apr 22, 2009
  • junkmailron Jan 29, 2011
    Thanks so much. It worked!
I have a tunturi t20 treadmill and there is no power to the digital display. Can you help?
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 13, 2017 | Tunturi Exercise & Fitness
My Tunturi C45 cross trainer has no display when turned on, can you help?
Dec 27, 2016 | Tunturi Exercise & Fitness
My tunturi 620p has a e2 code how can i fix it
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. check for tunturi treadmill articles
Feb 23, 2016 | Tunturi Exercise & Fitness
Have a J620P and just received a 51 code. What is it, and how do you fix it?
Follow the next step:
Scan by 3 seconds for to clear the error the display and restart the treadmill
If the error Do not appear,continue.Electrical fluctuation can be have actuated in the system electric power, and cause the display error.
If the problem persist call:206-881-7392 tunturi treadmill
God bless you
Oct 01, 2013 | Tunturi Exercise & Fitness
Error message "Speed Stall" stops will not run. :(
You must try a) LUBE very well the Deck belt and walking belt b) Recalibrate the machine.
If after this situation persist.
You must replace the EPROM(software is coming inside, and can be corrupt), call to the company.
for to get it.
Blessing.
How To Lubricate Treadmill
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 06, 2017 | Tunturi Exercise & Fitness
My tanturi treadmill model j620p indicate 51 in the panel. even i press the reset button still the 51 still in there. all keys does not work too. what shoul i do?
I will try to help you:
If any error code appears on the display or there are other
malfunctions, proceed as follows:
1. Turn off the power switch for a minute and then
turn it on again.
2. Insure the tether key is properly inserted.
3. Insure the power cord is properly plugged.
4. Insure the treadmill is properly lubricated (see 4.3.
LUBRICATING THE RUNNING DECK).
5. If the error code does not disappear after the
above mentioned maintenance actions, please
contact your local TUNTURI dealer. Always give
the error code and serial number (see the sticker
at the back of the frame, below the left-hand side
rail).
4.3. LUBRICATING
THE RUNNING DECK
Please apply teflon by using the pressurised can provided
with these instructions.
1. Let the treadmill run at a slow speed and spray
teflon into the lubrication .
2. When teflon is applied for the first time,
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 23, 2011 | Exercise & Fitness
I have a Tunturi j770 treadmill with error code E1. What does this mean please?
Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
May 17, 2010 | Exercise & Fitness
My Tunturi J620P stops and E-1 shows in display
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the powerswitch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 14, 2010 | Exercise & Fitness
Exercise & Fitness Logo
1,263 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
