Daewoo subwoofer aht-1000s
How to install a subwoofer home theater daewoo aht-1000s
SOURCE: Two Subwoofer Connections
on any home theater that is just for consumer use, unless you live in a VERY large house, only one sub should be necessary. using two could cause the amp to overheat and fry
Posted on Jan 30, 2009
  • 3 Answers
SOURCE: No Audio with home theater system
have you tried infra red link?
Posted on May 07, 2009
  • 7 Answers
SOURCE: Can I use this subwoofer for a home theater system
yes you could but you would need to soder and take the stuff apart
Posted on Jul 05, 2009
  • 21 Answers
SOURCE: trying to find a subwoofer
Don't underestimate what you can find at a pawn shop.
Seriously.
Posted on Nov 19, 2010
bookbundler
  • 649 Answers
SOURCE: Searching for a price quote on a DAEWOO AHT-1000s subwoofer speaker system. Rated power 15w max power 30w. Listed Audio System 6B75
Google it/ebay
Posted on Nov 04, 2017
Tip
How to install a 5.1 home theater system
1. Read the installation guidline/connection diagram given with the product.
2. u will get 5 speakers and a subwoofer. speakers are front left & right, rear left & right and center speaker.
3. install the front spearkers both side of the TV at ur ear level.
4. install the centre speaker at the centre above or below the TV at ur ear level.
5. install both the rear speaker at the back side wall corners (min 1.5 feet from ur sitting position) at a hight of 5 feet. face the speakers towards ur sitting position.
6. keep the sub woofer at the right side corner of the room.
7. note that the room should be a closed one with less air ventilession & use a carpet on the floor to get clear sound.
8. use co-excial or optical fibre cable to connect ur home theater system to ur TV, DVD player or audio device.
Now u can enjoy ur home theater.
on Aug 15, 2010 | Audio Players & Recorders
What type of fuse is used in the subwoofer?
Hugo Sepulveda,
The subwoofer uses the T1.6L250V fuse. You can get this at your local hardware store.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Oct 25, 2015 | Dell Mms 5650 5.1 Surround Sound Home...
How do I connect a Yamaha sws100subwoofer to onkyo home theater receiver
Use a subwoofer cable from the back of the Onkyo (it's labeled "SUBWOOFER OUT") to the subwoofers Input jack. It's an RCA style connector and can be bought at any electronics store or online.
Feb 16, 2015 | Yamaha Audio Players & Recorders
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
Jan 30, 2009 | Samsung HTZ-510 Theater System
My JVCTHC 9 Power subwoofer will not power up.
Assuming that you are using an amp have you checked the remote cable is giving the right voltage?
Jan 02, 2009 | JVC THC6 Home Theater System 5-Disc...
All five speakers are not working
Which One of the five speakers is not not working? LeftFront RightFront LeftBack RightBack or Center Speaker?
Sep 30, 2008 | JBL 5.1-Channel Home Theater Speaker...
824 people viewed this question
 Grubhead
Grubhead
