Question about Vizio P2 42 in. HD-Ready Plasma Television
Wide option on osd no longer highlighted
I NO LONGER HAVE THE OPTION TO CHANGE SCREEN SIZE TO NORMAL , WIDE, OR PANORAMIC.
  • 23 Answers
When you use an HDMI or component output and the device (cable box or DVD is set to only put out a 1080i signal te display will lock up. It is usually OK for the DVD player, however you may want to go into the cable box and check off all possible outputs ie: 480, 720 etc. This may allow you to chage display settings when needed
Posted on Feb 17, 2009
Picture doesn't fit screen. A 1-1/2 inch wide band on top and bottom of screen. Have tried the picture button on remote but it only gives me options ie: Panoramic, standard, wide etc. Nothing seems to
Many units will self adjust the image size, but the size of the image you will see depends on what size it was originally recorded in. You can change it in the settings of the TV but most likely it will not go bigger if it was shot smaller.
Feb 05, 2015 | TruTech PVS31170S1W 17 in. LCD Television
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
OSD Locks Automatically
hope this helps
Jun 07, 2012 | HP Computers & Internet
The screen on our 42"
  • Turn on your VIZIO HDTV. Press the orange button with the "VIZIO" logo, which looks like a letter "V" with a triangular wedge in the center. If there is no VIZIO logo button, press the "Menu" button. Press the "Right Arrow" button twice to highlight the "Setup" icon, which looks like a wrench.
  • 4
    Press the "Down Arrow" button three times to highlight the "Wide" menu item. Press the "Left Arrow" or "Right Arrow" buttons repeatedly until the correct aspect ratio is selected. "Normal" is for a standard definition 480i signal, which has a 3:4 aspect ratio. "Wide" is for high definition signals, and has a 16:9 aspect ratio. "Panoramic" stretches the outside of the image while keeping the center at the normal aspect ratio. "Zoom" enlarges the image on the screen. Press the "Last" button twice to close the VIZIO on-screen menu.
  • 5
    Watch the image on the screen of your VIZIO HDTV to ensure that the picture is at the right aspect ratio. If it still looks distorted, it's most likely because you chose the wrong aspect ratio setting, because your source device is set incorrectly or because you used the wrong connection method.
  • Feb 27, 2011 | Vizio VW42LF 42 in. LCD HDTV
    Unable to adjust the settings for brightness and contrast .
    To adjust the display settings:
    1. Press the flywheel control. The main menu appears.
    The current display settings appear across the top of the main menu.
    2. Rotate the flywheel to highlight an option. The name of the
    highlighted option appears in the center of the menu.
    3. Press the flywheel control to select the highlighted option, then
    rotate the flywheel to adjust it.
    Some options can only be enabled or disabled. There are also some
    options that contain additional menus.
    4. Repeat Steps 2 and 3 until you have made all your changes.
    5. Rotate the flywheel control until Exit is highlighted, then press
    it to exit the OSD control system.
    OSD OPTIONS:
    Contrast increases or decreases display image contrast.
    Brightness increases or decreases display image brightness.
    Horizontal Size increases or decreases the width of the display image.
    Horizontal Position moves display image to the left or right side of
    the screen.
    Vertical Size increases or decreases the height of the display image.
    Vertical Position moves display image to the top or bottom of the
    screen,
    Pincushion curves the sides of the display image inward or outward.
    Trapezoid increases or decreases the trapezoid distortion of the
    display image.
    Degauss removes magnetic discoloration from the display image.
    Recall returns most options to the original factory default settings
    if the monitor is currently using a preset video mode. (See the “Video
    modes” section in this guide for information about the factory preset
    modes.)
    Advanced Option opens the Advanced Option menu. Color opens the Color
    Manager menu.
    Language changes the display language for the OSD control system.
    User displays information about the monitor’s preset modes.
    OSD Manager moves the OSD control window on the screen.
    Exit closes OSD control system.
    Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
    Viewing mode will only go from zoom to wide!!!! please help
    Hi!
    Found some relevant info on how to adjust your video settings... You might want to give it a try!
    Thanks! =)
    4.12 PC Input Picture Adjustment
    The Picture Adjust menu operates in the same
    way for the PC Input as for the DTV / TV input in
    section 4.2 for Backlight, Contrast, Brightness and
    Color Temperature.
    4.12.1 Auto Adjust
    When the MENU button is pressed, the On Screen
    Display (OSD) appears on the PICTURE ADJUST
    page. Press the button to highlight the Auto
    Adjust selection.
    Press the button for the LCD HDTV to adjust to
    the PC signal timing automatically.
    4.12.2 H-SIZE
    Press the button to highlight the H-Size selection.
    Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
    the horizontal size.
    4.12.3 Horizontal Shift
    Press the button to highlight the Horizontal Shift selection.
    Press the button to start adjusting the horizontal position of the picture. Use the or button to
    adjust the horizontal position.
    4.12.4 Vertical Shift
    Press the button to highlight the Vertical Shift selection.
    Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
    the vertical position.
    4.12.5 Fine Tune
    Press the button to highlight the Fine Tune selection.
    Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
    4.14.1 Understanding Viewing Features
    Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
    You can switch viewing modes using the remote control.
    4.14.2 Viewing Modes
    Normal Mode
    The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
    added to the left and right of the display image. Standard TV broadcasts are
    displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
    to as pan-and-scan or full frame. These movies were originally filmed in 16:9
    (widescreen), and then modified to fit a traditional TV screen (4:3).
    Wide Mode
    When watching a standard broadcast or full-frame movie in this mode,
    the display image is stretched proportionately to fill the TV screen.
    When watching a widescreen (1.78:1 source) program or movie, the
    display image fills the TV screen. If you are watching a widescreen
    (1.85:1 or 2.35:1 source) program or movie, there will still be black
    bars at the top and bottom.
    Zoom Mode
    When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
    program or movie, the display image is zoomed proportionally to fill the
    width of the screen. The top and bottom are cut off to remove most of
    the source material’s black bars. This mode is good for programs or
    movies with sub-titles.
    Panoramic Mode
    When watching a standard broadcast or full frame movie in this mode,
    the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
    horizontally on the left and right sides to fill the TV screen. The center
    of the image is not stretched.
    Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
    mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
    will return to widescreen.
    Jan 04, 2009 | Televison & Video
    Vizio 37'' TV
    This is normal.
    Oct 21, 2007 | Vizio L37 Television
    Distortions in sides
    Sounds like you might be in the panoramic display mode... check your remote for a button labelled "WIDE" - it's on the left side just below the "GUIDE" button. Hitting WIDE will cycle through the various viewing modes (normal, zoom and panoramic).
    Aug 23, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
    Vizio P2 42 in. HD-Ready Plasma Television Logo
    96 people viewed this question
    Top Vizio Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
