Question about Cobra 148 GTL 120-Channels Base CB Radio
My 2000 gtl cobra has been cut on r131 what do i ned to do.thanks
  • David Shaub May 11, 2010
    What do you mean "Cut on r131"?
    Problem Solver:
  • 13 Answers
Nothing if it talks good if its overmodulating just solder r131 back together
Posted on Nov 11, 2009
  • ralph25texas Sep 23, 2010
    dude...cutting r 131 is a mod for good stuff if t=she talks...leave it alone... see cb tricks .com bennie( THE MAN) BOLIN does an excellent job for a free site that gets donations to help sever costs... you have a great radio..cobra 2k...i have 2 of them!!! ralph 25 texas way down south...
No but i would have to charge you for it
Posted on Feb 18, 2009
How to fix cobra 1000 gtl Powers up,meters stuck, no rx just static, All lights work, A mic will Key the on the air light,
have you checked the voltages inside the radio?If you have to much or to little it will not work properly.
Jan 19, 2014 | Cobra 2000 Gtl / 1000 Rf Pwr / Signal...
Cobra 148 gtl d has problem transmiting with covers off. trying to tune radio up. was thinking I need to ground the chasis
I would say a bad or cold solder joint on board somewhere. Bad quality control. Might flex radio chassis slightly while keying? A tooth pick and hours of probing around switching area on board and the pa section till problem found.
Oct 25, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
My cobra 148 work well on am but not on lsb
clipping the limiter should not have prevented tx on sideband are u sure u didn't do something more accidently. r 131 is the correct limiter for the 148. just out of curiosity what year 148 is it?
Jun 15, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Reset on the back of cobra gtl 2000 cb radio
the reset button is used to reset the cpu when doing mods.try replacing with momentary press switch.
good luck
ken
Apr 04, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Schematics for a cobra 148 NW
Most units do NOT allow modulation adjustment as any more than 90-100% modulation causes adjacent channel signal "Splatter" therefore is subject to restrictions, hence generally that is locked. Also there really is no reason to have more than 100% modulation..as well ... why? I would suggest a voice/speech "Compressor" would be more suited.
Jan 31, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Need a new Cobra 150 GTL DX power,vol,sqlch pot
you can write to parts department requesting price if you have a truck stop around you which has a cb shop they can sell u one
Jun 26, 2009 | Cobra 150 GTL DX Base CB Radio
Want to disconnect the bleep altogether on my cobra 148 gtldx
If this is a stock cobra 148 gtl 40 channel am plus side band, they don't to my knowledge come with a built in r beep. Some roger beeps are instaleed through the transmit circuit on the mic, so if not in the know Don't try to fix it.Some microphones have a beep built in. I used to install beeps on these radios using the pa/cb switch to turn them on. also try the nb switch or the swr/rf switch.
Feb 04, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 2000 gtl
cobra 2000
am carrier 4.4 volts will not ajust...ssb carrier will 3.5 volt will ajust but max out put is only 3.5 volts.losses all voltage at ssd carrier when switched to usd r lsb
Jul 03, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
296 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
