Question about Copystar CS-2020 Copier
I have a Copystar CS-2020 and it is showing error code A-O 410 on the screen what does this mean
  • 26 Answers
Document Processor communication problem. This is due to a faulty ground connection.
Open the doc feeder lid, check the left hinge. There are two versions of grounding tab: a small one and a bigger and better one. Both attached by a screw.
Twist the small metallic tab that grounds the hinge with doc feeder metal frame in order to create better contact. Worst scenario, the doc feeder cable has a broken ground wire at the holding strap (inside the back rear cover of the feeder, which is hold in place by plastic clasps. If you are handy you can solder the wire ..
Posted on Feb 21, 2009
My copystar printer is showing error code c6040
This is fuser unit error code, you can try reseting it by running mode 163, if it doesnot work you need to replace the fuser unit.
Mar 14, 2014 | Copystar Office Equipment & Supplies
Error code c410 on cs-2218
If a C410 Error occurs, replace the DP-410 Main PCB Assembly, Ground Wire and Screw.
The PCBs part number is 303HL01018.
Apr 01, 2013 | Copystar Cs-2218/cs-2221/cs-2225 Developer...
C-6 400 what does it mean on kyocera KM-2020 photocopier machine
Hi my Kyocera KM2020 is showing an error code C-6 400, what does it mean and how do I fix it? Thanks
Jan 29, 2013 | Copystar CS-1650 All-In-One Laser Printer
Copystar CS1810 shows error code J00. How do I fix this?
J00 means that the machine did not pick. remove the cassette and the put back and press start again
Feb 15, 2011 | Copystar CS-1810 Copier
Error code C4000 For a Copystar CS2050
it's mean's laser problem need to change it
May 07, 2010 | Copystar CS-2050 All-In-One Printer
I have a brand new Copystar CS-3060 turn it on and a ERROR CODE 3100 appears on the screen what does this code mean please??????
The scanner is locked...look for some large yellow screws on the side of the machine or on the rear of the machine inside of a detent. Turn it left until it pops out to release the scanner.
Mar 11, 2010 | Kyocera CopyStar CS-3060 Black and White...
We just need a manuel for the copystar 2020 free download would be good.
try usa.copystar.com... if its not an american model then goto the main copystar site... copystar.com and search for your region and then search the support section or download section for your manual... if you want a service manual google it and many places online will gladly sell it to you...
Nov 04, 2009 | Copystar CS-2020 Copier
E33 Error Message
Im pretty sure the E33 error means the toner is empty, so you need to replace the toner.
If you have already done this, make sure everything is correctly seated and firmly closed.
Here is the manual incase you get any other problems, page 95 addresses your mentioned problem..
Copystar CS-2020 Manual
Regards
Mike
Sep 03, 2009 | Copystar CS-2020 Copier
Unrecognizable error code
press 10871087 menu will appear then go to c codes list
Apr 09, 2008 | Copystar CS-2050 All-In-One Printer
Copystar CS-1810 Error Code
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Mar 19, 2008 | Copystar CS-1810 Copier
Copystar CS-2020 Copier Logo
159 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
