Question about Juki Sewing Machines
JUKI MO2515 MANUAL
MISSING INSRUCTION MANUAL AND CAN'T ARRANGE THE THREADS.
  • 19,396 Answers
Here is Juki download page.
As your model is not listed you will need to contact Juki to get the manual, write them an email, see: Contact Us.
Posted on Feb 17, 2009
Juki 98P. Was using walking foot when needle stoppedgoing down into the material. No threads stuck. Turning handwheel doesn't make any difference. Turns so far and no further
Hi Wilma, could be a gear problem, try calling your local sewing machine repair shop, for more information about your question please visit the website below. Good luck and have a nice day. https://www.juki.co.jp/household_en/pism/img/tl98p/download/98pim.pdf
Sep 25, 2015 | Juki Sewing Machines
Juki sc320 material stuck
if your fabric is stuck the liklihood is that the spool underneath is jammed up with threads take out spool and clear threads replace spool, it should be ok then
Jan 05, 2013 | Juki Sewing Machines
Serger motor locked up completely
I suggest taking the machine in to be serviced
Jun 09, 2012 | Juki MO-644D Mechanical Sewing Machine
Back thread loose and loopy - tension
If you have the instruction manual, you might read the chapter which describes the proper adjustment for threads and fabrics.
If you do not have one, try to find it on eBay. It is the huge source of everything.
Feb 20, 2012 | Juki MO-644D Mechanical Sewing Machine
I want to adjust my serger yuki mo 2516n but i don't still have it's manual instructions
if you go to this page http://www.juki.co.jp/household_en/serger/index.html there are the current household sergers from Juki and a four page threading diagram for them showing the different stitch set ups.
If your serger is a domestic one too (the MO in front makes me think so) then you may find that the threading up is very similar on your model. Stitch length is usually a kob on the right marked from 0.5 to 4 and differential feed knob is usually there too, usually marked from -0.5 up to 1.5. Tension settings are usually around 5 but you adjust the looper tensions to suit the fabric and how wide you are trimming it with the blades.
You could contact Juki or their local distributor in your country and arrange to purchase manual for your model. http://www.juki.co.jp/household_en/dl/index.html this page gives a listing for countries.
it is also available on line to purchase as a black and white pdf file, http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/MO-2500_Instruction_Manual.htm for $8USD
Jun 20, 2011 | Sewing Machines
I have Juki MO-644D It has been working very well untill now
have you got the solution to this, cuz mine is doing the same... :/
Jul 10, 2010 | Juki MO-644D Mechanical Sewing Machine
Missing manual
Hi I hope this helps. These are United States contacts. Thank's, Jeff http://www.juki.com/contacts.html
Jun 22, 2009 | Juki DDL-8300
Double needle use on Juki HZL-E80
if the machine regular needle threads front to back NOT side to side, you can use a double needle. simply pass both threads thru all the same slots (thread one at a time so they don't get twisted up) then just before the needles, leave one out of the thread guide just above the needle. you may have to loosen the top tension SLIGHTLY, like a half number. and do NOT use a zig zag stitch without first hand cranking it thru the cycle to be sure the needles clear, or you'll make a 5.00 mistake (the cost of the double needles!)
Jun 16, 2009 | Juki HZL-E80 Computerized Sewing Machine
I have a Juki MO 3716 and I cannot thread it. Please help. It has four threads.
I also own a Juki MO3716. It is a five thread not a four as it has three lower looper threads. Two are fed through the front, just follow the color codes and the threading diagram on inside plate that you lower to see the threads, the third is threaded through the back and around the left side. I can send email with picture of diagram if needed. the other two threads are for the two top needles. This machine is a true safty stitch with the overedge row of serging and an inner chain stitch row for secure seaming. You can run this machine quite nicely with only three thread ( one inside needle and the two front loopers. If you need further held email me at wanmacinnes@eastlink.ca
May 23, 2009 | Juki Sewing Machines
I want to have my Juki MO-2516n do a mock safety stitch/4 thread
I have a Juki MO 2516N. It does not have the capability to serge 4 threads. The only options are 2, 3, and 5.
Apr 28, 2009 | Juki Sewing Machines
Sewing Machines Logo
549 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
