If you ride the clutch and let the rpms go down then shift it doesnt grind most of the time.
Check that you are using the correct grade of oil in the gear box. IF you have it is possible that the synchro ring for 2nd gear is failing and not energising the 2nd gear hub. That means box out for a rebuild
SOURCE: gears grind when shifting
Sounds like the clutch needs adjusting or repairs. If there is more than 1 inch of free movement at the pedal then it needs adjusting.
SOURCE: clutch/transmission problem
When the car is sitting idling,and the clutch is not depressed,it makes a grinding noise because the input shaft of the transmission is being forced to turn by the clutch,which is engaged,and even though the trans is in neutral,the input shaft is still turning,and this is called "neutral roll over" noise,and some of the assemblies inside the trans are freewheeling around.The noise goes away when the clutch pedal is being depressed down,because the input shaft of the transmission is no longer turning.So it does sound like an internal transmission problem.It is still possible for the throwout bearing to be bad,and it can be checked when the trans is removed from the vehicle,Remove the throwout bearing from the trans input sleeve,and press down on the bearing flange and turn it at the same time.It should feel smooth and free.If it catches or feels gravelly,then the bearing is bad and that could be your noise.Also,turn the input shaft of the trans and same thing,if it's smooth and free or if gravelly feeling......Good luck.
SOURCE: 1999 Grand Voyager transmission not shifting into high gear
Do yourself a favor & get it scanned at transmission shop, or dealer & fixed as needed,(within reason) . Delaying it could cost lots of money. A rebuilt is about $1500-$2000.
SOURCE: 1993plymouth laser grinds while shifting. want to
adjusting a clutch is no problem providing you have an adjuster ,if its not clearing then the lock nut needs to be be slackened off and the adjuster screwed in till the clutch pedal is the same height as the brake pedal and thats all their is to it ,Now the adjuster is on this car i have no idea sorry here but iam euroepon mechanic whos never seen this model
