Question about Sony Cyber-shot DSC-S700 Digital Camera
I cannot get the camera to start , CHANGED THE BATTERIES ,BUT STILL WILL NOT START , PLEASE POINT ME IN THE RIGHT DIRECTION , THANKS
  • 8 more comments
  • Anonymous Feb 21, 2009
    YOU PEOPLE ARE NO HELP
  • lonny298 Mar 04, 2009
    My camera won't turn on, please tell me how to fix.
  • Anonymous Mar 25, 2009
    i press the power button and there is no response though the batteries are new and correctly installed
  • alwittenberg Apr 10, 2009
    I have the same problem. My camera has new batteries, and when I push the power button it just flashes cyber shot, and turns off again
  • stephany2 Apr 12, 2009
    Has any one found a fix?
  • Anonymous Apr 18, 2009
    I just can NOT start the camera. When I press the Powerbutton, nothing happens?
    HEP, HELP!
  • Anonymous Apr 26, 2009
    It was working perfectly fine when it shut itself off. The lense is still out and I have replaced the batteries a few times now, all new and it will just flash cyber shot then shut off
  • OPERATOR NEO May 01, 2009
    I TAKE 2-4 PICS THEN IT TURNS OFF BY ITS SELF, CHANED THE BATTERIES AFEW TIMES (NEW ONES) BUT IT DRAINS THE BATTRRIES THEN SHOTS OFF AGAIN.
  • Anonymous May 10, 2009
    I have the same issue. It worked the other day. Today it won't work. Nothing happened to it. Never dropped it or got it wet. New batteries.... still nothing. Where's the reset button it's supposed to have???
  • Anonymous May 16, 2009
    I have the same problem with not being able to turn the camera on and the battery draining. I do not recommend the Sony cybershot camera - i have had this problem on and off since i got it. Does someon have a solution on how to fix?
Posted on Feb 21, 2009
How do i get my camera to start up help?
First, do you know for sure it was working when you bought it?
Second, are your batteries all good?
Third, make sure you have all the batteries installed the right direction.
Finally, make sure the compartment door is properly shut.
I really don't know much about cameras, just advising of some of the basic things I would double and triple check first.
May 16, 2014 | Canon PowerShot S5 IS Digital Camera
I have changed the fuel pump and got some pressure but then it wouldn't start again so I changed the fuel pump again but this time I changed the fuel filter but the car wouldn't start and I'm not getting...
check fuel pump. can you hear a buzz noise when u turn key to on. if not check your relays to fuel pump and fuse. need like 50lbs of pressure. is filter going in right direction?arrow should point to engine.
Apr 01, 2011 | 1998 Chevrolet Malibu
My digicam won't start
There could be a couple of reasons why your camera would not start.
Before considering it to be defective, verify that the camera has batteries inside and that these batteries are charged. To do this:
  1. Locate and open the battery compartment.
  2. Identify the type of batteries needed and purchase new ones OR
  3. Recharge the batteries with the recharger provided.
  4. Place the new/charged batteries inside, closing the battery compartment.
  5. Try to turn on the camera.
If the camera still doesn't work after verifying that the batteries are in order, remove the memory card and any other accessories that the camera may have and try turning it on again.
If still the camera won't turn on, one last step can be performed if and only if your camera uses standard batteries (AA or AAA). If this step is performed incorrectly, you could short circuit the batteries, which would discharge them. This procedure will not damage the camera if performed correctly. Please pay attention and do exactly as explained:
  2. Remove the batteries.
  3. Place the batteries back inside in the opposite direction than the one indicated. If the position indicated is for the positive end first, place the battery with the negative end first. Do this process for all the batteries.
  4. Close the battery compartment.
  5. Attempt to turn on the camera. It will not turn on, but this step is necessary nonetheless.
  6. Open the battery compartment.
  7. Remove the batteries.
  8. Place the batteries in the correct position according to the indication.
  9. Close the battery compartment.
  10. Attempt to turn on the camera.
If the camera still does not work, it is likely that it is defective. At this point you should take the camera to an authorized service center.
Mar 30, 2011 | Cameras
Battery exhausted
You don't mention anything other than battery exhausted but this could be for a few reasons. Obviously the L20 Coolpix uses standard AA batteries so they need to be replaced with fresh new ones when they start to run down.
If you use rechargeable AA batteries then there will be a point that the batteries no longer "hold" a charge and they will also need replacing.
If the batteries are fresh and the camera is running them down very quickly then you will need to get it professionally looked at for repair, I would imagine though that a repair would cost more than the L20 is now worth.
Hope this helps, please rate my help if it does. Thanks
Nov 03, 2010 | Nikon COOLPIX L20 Digital Camera
Lens error 115, 0 0 215
Kodak usually points to underpowered batteries as being the culprit of lens errors like that. They generally point to using Kodak brand digital camera AA batteries. You can do that, but I usually recommend Varta Brand. Sold mostly in camera stores and in small quantities, so they are usually VERY fresh - and they are designed for the high powered needs of a digital still camera.
But if it's under warranty, I'd send it in to get looked at anyway. Go over to KODAK.com and get into their support webpage and have a "chat" with a rep. They'll point you in the right direction.
Jul 04, 2009 | Kodak EasyShare C613 Digital Camera
Rechargeable battery replacement
Check out this link, it has details on how to change the batteries (halfway down the page). It's also got a picture that should point you in the right direction.
Link here.
Mar 18, 2009 | Canon PowerShot A70 Digital Camera
Olympus Camedia digital camera D-535 ZOOM. When I turn the camera on, it turns itself off. Then when I turn the camera on again, the two buttons on the right side of the screen light up ~~ top one red and...
Although the batteries were new, they were not working. I changed the batteries and now the camera is working well. I still don't have instructions for the use of the camera. PLEASE SEND WRITTEN INSTRUCTIONS. Thank you.
Sep 12, 2008 | Olympus Cameras
Sony Cyber-shot  DSC-S700 Digital Camera Logo
385 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
