Question about Venturer Televison & Video
Need a manuall for plv71198s20 19inch tv and dvd player just bought and no idear how to set it up please help
SOURCE: toshiba dvd setting
1. You would press and hold stop on the front of the unit for 5 seconds then let go and press it again normally, you can try this with both the power of the unit on and off.
Posted on Sep 24, 2007
  • 7 Answers
SOURCE: new dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Posted on Dec 25, 2007
SOURCE: need codes for rca tv, jsi dvd player
try the code for Koss or Ornitron.
Posted on Jan 05, 2008
SOURCE: Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Posted on Aug 18, 2008
  • 9 Answers
SOURCE: URC-4021B00 codes
http://www.oneforall.co.uk/us_US/support
Posted on May 24, 2009
I bought pioneer muti system dvd
Check your DVD player's color system, most multi system dvd player has to be set(PAL or NTSC) manually, NTSC for American standard. Look for this button could be a mechanical switch at the back or at the menu. Some machine need to reboot after setting. Hope this helps
Mar 04, 2010 | Samsung DVD-V90K Multisystem DVD/VCR
Insignia tv ..can't get sony dvd to work
You most likely need to set the TV to the input source where the DVD player is connected (e.g. AV1, HDMI2, etc.) Without knowing the model number of your TV, I can't be more specific. Details on changing which input source you're viewing should be in your TV owner's manual.
Sep 19, 2009 | Sony DVP-NS55P DVD Player
Hello
You should first ensure that all the cable connections are firmly affixed both to the dvd recorder and the tv you are trying to use it with.
Secondly - it could be due to settings on your tv that the player isnt working. Check through your TV's manual for tips on how to adjust all the settings on your tv.
If all else fails return the unit. Send it back to whereever you bought it form or if its still in warranty, back to the manufacturer.
Nick
Sep 03, 2009 | JVC DRM10 DVD Recorder
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
I just bought a memorex mvd2042 dvd player and i can not get the tv guardian to work because i dont know the pass word can you please help
TV Guardian is a seperate company and you have to set up the service through them. Please visit
www.tvguardian.com and set up the service. They will provide you with what you need.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 15, 2009 | Memorex MVD2042 DVD Player
How to Connect my Cyberhome CH-DVD 300 from my TV that has SCART interface to Component Out on the DVD player
You have not mentioned the t.v/ dvd model, normaly all latest t.v will have A.V. input , try to connect in a.v. out of d.v.d to a.v. input to t.v and bring t.v. into a.v. mode.
Jun 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Please help
You can find the manual here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=b7a9e24543cb9cdef7c4e094fb734a9a&q=Sanyo+DWM-400
They will make you enter your email address if you want to download the manual.
I'm not sure you'll need the manual if you have a newer TV and want to hook this up the way most people do.
Just about all new televisons have a variety of video inputs. Typically you use one for your Cable box, one for your DVD (or VCR). When you wish to watch cable you "tell" your TV you want to view that input and when you want to watch the DVD player you tell the TV that's the input to use. Most Cable Box remotes are set up to control the TV so you can change the input without having to use the original TV remote. You can also, generally, change the TV input from the front panel of the TV set. If you give me the make/model of your TV I may be able to help you figure out how to switch inputs.
But back to the DVD. I downloaded the manual and this DVD can generate output in a few different formats. The easiest will probably be the jacks numbered 2 which is the Audio There are two them, one is RED, and one is WHITE, and jack number 4. This is the Video and will be YELLOW in color. I'll be the DVD player came with a cable set that has three connectors on each end. They will be colored YELLOW, RED, and WHITE.
You should simply need to plug one end of this cable set into the jacks mentioned above on the DVD player and then plug them into one of the inputs on your TV. Pay attention to which TV input you use because you'll need to select that input to watch the DVD.
If you have an older TV we will need to use a different method to hook up the DVD player.
Now for the editorial section. I'm not paid for this. I know it's a strange hobby, but I like helping when I can. If you have more questions please ask before you rate this solution. If anything I've offered here has been helpful I hope you'll rate this solution positively. About half of the solutions I've offered have never been rated. Thanks and good luck.
Jan 09, 2008 | Sanyo DWM400 DVD Player
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
Having problems connecting dvd vcr combo to tv
Hey Pat. Red Yellow White Plugs into back of MVD4544. Red Yellow and white plugs into back of TV. If you have an older TV that has only coax cable outlet, go to Radio Shack or Best Buy and get an RF Modulator. You may need to get another set of Red Yellow White Plugs if you have a cable box. The front connections are Video 2, if placed on the back they are Video 1. When you first turn the DVD/VCR player on, be sure to select the appropriate setting. If you figure out how to timer record on this please let me know. No where in the 52 page book is there any info and their website is a joke. Good Luck.
Sep 14, 2007 | Televison & Video
Televison & Video Logo
67 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
