Question about Acer Aspire One PC Notebook
My aspire one cannot pick up single from my desktop
My desktop is wireless but my laptop cannot pickup single
  • jacdink Feb 17, 2009
    My desktop has verizon wireless broadband and according to the box my acer aspire one came in the mini laptop is supposed to be wireless yet i still cannot get a signal from my desktop
    thanks for the advise but the problem still exists
  • Acer Master
  • 13,433 Answers
Hey,
On the laptop, make sure the wireless switch is turned to on, and that the wireless led is on.
not much else, then make sure its turned on in windows or the operating system you got installed on it and it should see the networks.
if not, then I suggest you get someone to look at it to confirm the problem.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 17, 2009
  • Ekse Feb 17, 2009
    Your trying to connect it to your desktop computer? I would suggest you get a wireless router to connect it to. it will work better this way.
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
Acer Aspire 7540 won't connect to wireless or ethernet
Ensure the Acer software is installed along with the system and boards drivers.
Jan 10, 2018 | Acer Computers & Internet
How to enable wifi in acer 4720Z
Acer Aspire 4720 has a wireless button to enable/ disable the wireless communication on your laptop.
You also refer to Acer 4750Z Manual for further information, if required.
Hope it helps! Good Luck!
CreativeTECH
Feb 23, 2011 | Acer ASPIRE 4720Z-2A0508MI LAPTOP LCD...
How do i turn the wireless capabilty on? my internet was working fine i restarted my laptop and now can not pick up my wirless, its saying that my wireless capability had been turned off, how to i put it...
Look for a WiFi button to ensure it isn't off. If it isn't, then go to the Control Panel and go to Device Manager (Hardware Manager in Vista) and make sure the device disabled. Right click it and choose Enable. Should pick up your wireless.
Jan 14, 2010 | Acer Aspire 6930-6771 Laptop
I recently purchased a new battery for my acer Aspire 3050 and was told that it wont work if my laptop was dual core.I'm not sure what that means, is my 3050 dual core
you are in luck the answer is no its not dual core
Acer Aspire™ 3050 (LX.AV10J.037) PC Notebook The Aspire single core™ 3050 from Acer® provides performance, flexibility and value in a compact system. Featuring an AMD Sempron™ processor, wired and wireless connectivity and a stunning 14.1” WXGA display, this notebook brings productivity and entertainment to a new level.Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Acer Aspire 3050-1733 Notebook
Wireless connection
Sometimes the wireless card will pick up any signal it finds, like your neighbors..go into control panel and network connections and take a look if there are other signals being picked up. If so there will be more than one connection showing. Click on your connection and that should set it to automatically always connect to yours and not someone else's...if the wirelss card was not functioning then you would not get any signal at all...finally try starting your laptop next to your router and see if that works better, there may be some interference in the house not allowing you to get a strong signal..good luck. Please rate this solution.
Mar 08, 2009 | Acer Aspire 5610-4648 Notebook
My desktop uses a DSL internet connection but my lap top will not pick up the signal from it to connect even when I have it sitting right next to my desktop. If I actually unplug yellow connection cord...
Having your laptop sitting next to your desktop will not let your laptop connect to the DSL link.
You need what's called a Wireless Router. (assuming your laptop has a wireless adapter, if not you'll need a network cable for that.
1. Go to the store, buy a wireless router
2. install router in between your DSL modem and the computer.
3. Plug the WAN port into the DSL modem (cable is usually included with the router)
4. Plug the desktop into the back of one of the ports of the wireless router
5. Run the setup disk
6. For manual configuration of the router you can usually go to: 192.168.0.1 or 192.168.1.1 or 192.168.2.1 depending on the brand)
7. If you don't know anything about networking, let the install disk do all the work.
8. Follow the instructions on what it tells you your configuration is for your wireless network.
9. Go to your laptop, apply said instructions.
10. ???
11. Profit.
Dec 02, 2008 | Acer Aspire 5050-3242 Notebook
Quick Question regarding a set up
correct you only need a wireless card or usb adapter is it a laptop or desk top unit? in any case a wireless adapter should do just fine
May 04, 2008 | Linksys Wireless-G WRT54G Router
Wireless shuts off my laptop everytime I turn it off.
1.You probably have the internet connection shared through your computer..
2. you are either on a different channel or too far away.
Jan 17, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire One  PC Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
