Question about Sony Grand WEGA KDP-51WS550 51" Rear Projection HDTV
Sony kdp51ws550 No picture after turning off but sound works.
This problem occured before but after awhile it would come back on. The diagnostic LED is blinking 10 times. I have a multimeter and the back taken off. I have some technical knowledge (low voltage electrician) and can check for continuity, voltage, and resistance. I just need to know what the meter readings should be and where ie should Q8013 and Q8014 read the same? Can anyone help? Thanks, Mike
2 Suggested Answers
SOURCE: Where can I find Q8014, Q8013, R8051 and IC8005?
where exactly is Q8014 and Q8013? where is board D? How would I know if there are bad? and where exactly is R8051 and IC8005? so I can check and if possible fix it myself. I would really appreciated.
Posted on Oct 14, 2011
Sony Bravia KDL-40EX500. Plugged in power and no backlight. No pic no sound. Could it be the power board or inverter board? How can I test these boards? Thanks.
SELF DIAGNOSIS FUNCTION
The units in this manual contain a self-diagnostic function. If an error occurs, the STANDBY LED will automatically begin to fl ash. The number
of times the LED fl ashes translates to a probable source of the problem. A defi nition of the STANDBY LED fl ash indicators is listed in the
instruction manual for the user's knowledge and reference. If an error symptom cannot be reproduced, the remote commander can be used to
review the failure occurrence data stored in memory to reveal past problems and how often these problems occur.
DIAGNOSTIC TEST INDICATORS
When an error occurs, the STANDBY LED will fl ash a set number of times to indicate the possible cause of the problem. If there is more than
one error, the LED will identify the fi rst of the problem areas.
Result for all of the following diagnostic items are displayed on screen.
If the screen displays a "0", no error has occurred .
Diagnostic Item
Description
Number of times Standby
LED blinks Possible Location
Main Power Error 2 G2HE/GD2 (Power) Board
Audio Error 3 A (Main) Board
Balancer 4
LCD Panel
Inverter Board (ETC-Inverter MT Board) for 32" & 40" Models
TCON Error
5
LCD Panel
TCON Control MT Board
HFR Error 5 LCD Panel
Backlight Error 6
LCD Panel
Temperature Error 7 A (Main) Board
This should help you narrow it down. I am also attaching the service manual for you. https://files.acrobat.com/a/preview/16a56e45-a439-48bc-8770-21638f2bab68
Jul 04, 2016 | Sony Bravia Kdl-40ex500 Series 40-inch Lcd...
I HAVE A SONY-KV-ES34M61TV,PICTURE GOOD,SOUND GOOD BUT LIGHT BLINKIG FIVE TIMESWHEN NOT PICTURE ON TV SCREEN FLESHING LIGHT IS STOP, PICTURE GOOD,SOUND GOOD BUT IN SELF DIAGNOSTIC SCREEN DISPLAY 005:255,IT...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Sony Televison & Video
Hi! I have a Sony KDL-40s2530 that stopped working properly. When turned on the picture goes on for about a second then it turns off and the red light at the lower right starts blinking four times with...
Most likely this:
4X Blink error code = Balancer Error
The 4X blinking error code is used on models which have a dimming LED backlight.
If a failure happens the TV will shut down and display this diagnostic code.
Contact Consumer Electronics support for repair options.
http://esupport.sony.com/US/p/support-info.pl?info_id=932
Oct 20, 2017 | Sony Televison & Video
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
Sep 02, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony 46" rear projection LCD HD - picture and sound go on and off
personally i would call a tv repairman out to fix the set.you can get alot of different opinions on here about what it may or may not be but the best thing to do is call a repaiman and let them fix it
Jan 27, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony KDP51WS550-LED light blinks 10 times
This is usually a problem on the high voltage board. When you first turn it on, the main board does it's P.O.S.T., then powers the HV board. You'll be hard pressed to find a replacement for it. You MIGHT find someone that can rebuild it, but for the money? Time for an open box special at you local electronics place.
Jul 02, 2017 | Gateway GTW-P42M303 42 in. Plasma...
SONY-LED BLINKS 10 TIMES
OK, 10 times is HV protection (High Voltage) and problem can be in D board and Q8013, Q8014 can be shorted along with R8051 open.
also IC8005 can be damaged.
All above parts on D board.
I would recommend to get related service manual for proper diagnose of problem in TV.
Good luck.
Dec 17, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv wont turn back on
Hii.... first I like to know the chassis of yor KV27FS100..
sound like problem with regulated parts block.....and can more helpfull if you count the blinking of the LED....sony have selft diagnostic at the LED Blinking.....
I hope hear from you soon....
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Grand WEGA KDP-51WS550 51" Rear Projection HDTV Logo
243 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
