Question about Ahead Software Computers & Internet
Dvd drive whenever i insert any cd/dvd in my drive it dosent read
  • 13,433 Answers
Hey,
most of the time its a broken down drive. do you have warranty on it? if you do, get warranty repairs.
if you don't, then try it on another computer if you can if it does the same thing on another computer, then its definitely faulty, you could try a lens cleaner they don't cost much.
look for a lens cleaner like this or similiar
http://www.officemax.com/omax/catalog/sku.jsp?skuId=21180473&cm_mmc=GBase-_-Technology-_-Computer_Accessories-_-Computer_Cleaning_Supplies&ci_src=14110944&ci_sku=21180473
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 17, 2009
THE DVD/CD-ROM DRIVE DOES NOT PLAY THROUGH THE ACER ARCADE OR WINDOWS MEDIA PLAYER WHENEVER I INSERT A DVD OR CD-ROM. WHAT COULD THE PROBLEM BE SIR?
Autoplay might be turned off.
open up "My Computer" or "Computer" and double click the drive and see if it reads that way.
If not, clean the lens on the drive.
If that doesn't work, you will likely need to replace the DVD drive or take the computer in for service.
Feb 22, 2011 | Computers & Internet
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
I can't insert any cd's.
Maybe the laser eye is jammed. It tracks back and forth reading data from the disc.
You may either replace the drive or have it repaired.
I had one on my PC do the same vibrating, clicking noise. It only cost 40.00 to replace.
But for a laptop, you're looking between 60-100 dollars to replace.
You can see how much it would cost to repair first, but my guess is it would be cheaper to replace.
Jul 12, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Can my cd /dvd player write too?
You can also verify the users manual. Mostly you can see some code in the CD-ROM like: DVD-RW= Can write CD and DVD DVD-R= Can only read DVD's CD-R= Can only read cd's. CD-RW- Can write CD's only.
Jun 10, 2009 | Computers & Internet
Can't read CD but can read DVD
This is not uncommon. I have seen it often. It is a sign that the unit is about to fail, and needs to be replaced.
I don't know where you are, but around where I live, these dual layer DVD RW drives retail for less than 30 dollars. They usually come with software and are not difficult to install.
Beware of ESD, however, whenever you are working on the inside of a pc. ESD (electo static discharge) can destroy the insides of your machine without you knowing it until it's too late.
good luck
tony
May 20, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
DVD writer doesn't read cd's but it reads DVD
sir
its the problem with your DVD ROMS's lens. It has became weak . Due to which it is not able read the DVD. It cannot be repaired but you can do few things to make it work again.
  1. open the DVD ROMS if possible
  2. try to clean dust from inside
  3. and then try again
or if not able to open it
buy a lens cleaner form market and try to clean with it .
thankyou 4 using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | LG GSA-H55N DVD-RAM Burner
Not reading DVD
DVD drive is not reading the disc inserted.It does not show up in any of the drives of My computer. Mahesh Kanade.
Dec 26, 2007 | Computers & Internet
LG GSA-4167B DVD Writer... PC restarts whenever any CD is inserted
What is happening is that the dvdrom firmware or the laser is failing and cannot read the disc; and because the pc is using all the system resources trying to do so; it appears that you cannot get anything to run, making it seem as if the hard drive is faulty also, though not the case. You will need to replace the drive if this is a common occurance, as the life of a dvd drive nowadays dependant on use is aprox 2 years, because as the prices come down so does the quality of the laser required to burn and read discs.
Aug 25, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
Computers & Internet Logo
26 people viewed this question
Top Ahead Software Computers & Internet Experts
celos
lemesee
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
