Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
No power on my Magnavox DVD Recorder/VHS Player model #MWR20V6
This is a remanuafactured item sold by Heartland. I had it for about 3 weeks. I only used it like 3 times to watch some movies and the next time I turned it on it would'nt come on. No power to the unit at all. Just to make sure it was the unit and not the outlet I plugged it in to several other outlets in my home and still no power at all. I don't know what is causing it. I called the number on the back of the unit and they gave me the run around. I have called and can never get through. Can someone give me an idea on what is wrong with it and how to fix it? Thankyou.
5 Suggested Answers
SOURCE: Need a replacement remote control
http://www.remotes.com/remotes/servlet/rs?uid=11947368000620&o=c&da=Search&m2=mwr20v6
Posted on Nov 10, 2007
epik559
  • 44 Answers
SOURCE: Philips Magnavox MWR20V6 DVD
Its macrovision. You need a macrovision killer or a Go video. I am not promoting you to buy that but that would take care of the problem
Posted on Nov 25, 2007
SOURCE: unable to record/dvd recorder problems mwr20v6 phillips
I also have same problem and have had no luck with anything I have tried
Posted on Aug 03, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
Posted on Feb 15, 2009
  • 814 Answers
SOURCE: Dont know how to finalize dvd after recording on magnavox vcr/dvd
You can find a copy of the manual on the web link provided here:http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html Print a pdf copy for yourself. If you need more help the customer care for you dvd/vcr player is at this telephone number. 1-800-605-8453 give them the model number of your dvd/vcr unit and they will be able to help you. I hope this information helps you with your problem.
Posted on Jun 02, 2009
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox DVD/VCR Recorder ZV457MG9 How do I finalize my DVD on this player/recorder?
http://www.ehow.com/how_8623235_do-finalize-magnavox-dvd.html is how to finalize a disk on Magnovoz! I have the ZV457MG9 - its model takes with
1) loading disk
2) select the set up button
3) select DVD edit
4) select finalize DVD
Then you finalize the DVD!!!
Jan 31, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
We moved and lost the manual for magnavox vhs/dvd player and recorder
Go to this link which is Funai the manufacturer of your DVD Recorder. Type in the model number on top right side and the manual download will show up.. It did for me
http://www.funai-corp.com/support/manuals.aspx
You will need Adobe Reader to open the PDF file. If you dont already have it you can get it here for free
http://get.adobe.com/reader/?promoid=BUIGO
Nov 25, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Have a Magnavox MWR20V6 - have a few things going on, one the power shutting off automatically when i put the vcr on timer and therefore does not record, and 2 vhs tapes that are almost new, gets stuck
Junk it. It's identical to Funai WV20V6. I can't remember exactly what is causing the shutdown. But, I do remember that it says it can't be fixed. Read other posts here at Fixya.
"Funai wv20v6 dvd/vcr player recorder"
Mar 17, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox MWR20V6
The unit has to be turned off for the timer to activate. Let me know if it works.
Jul 23, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox MWR20V6 problem
on my magnavox mwr20v6 i cant record my vhs to dvd i get black screen every time and my DVD are new and I just open my magnavox after a long long time and ecsup for get my VHS record to DVD it is fine I would like to fix this issue :(
Jan 01, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
Type in the box: MWR20V6
Nov 09, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sorry Gary, Forgot to put the link on: http://www.originaltrilogy.com/forum/messageview.cfm?catid=12&threadid=6530
Aug 24, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
331 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
