Back to:
Tags:
Macally iShock Game Pad
Ishock Macally gamepad.
By Bouncy - usenet poster
Anybody know how good it is?
Do you like it??
Paul
Paul Graber
Ultima Dragon and Classic Gaming Enthusiast
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Perkins
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Avelino Santa Ana Jr. <
I've seen you post this several times, but I must claim that I have not
had the same problem. While I haven't run MacBench, I get the same
frames per second in UT whether the extention is enabled or disabled.
Also, disabling the iShock driver for some reason decreases the
inputsprocket compatibility, and so I have to leave it enabled. For
example, in MacMame when I have both extensions enabled, I get full
customization over every button on the pad. However, when I turn off
the iShock extension and just keep the IS extension, then when I go to
MacMame the configuration screen gives me a very limited set of
options. I can no longer configure the movement pad or the analog
sticks, so for the most part it is unusable. I have the newest version
of IS, but I guess it doesn't know how to configure the gamepad
correctly unless the extension is enabled. Dunno
Jamal
jamalb at mac dot com (please delete crap for reply via email)
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Ishock Macally gamepad.:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Beresford
Rating: 0%, 0 votes
One thing you need to watch out for is the iShock's extension which
enables non InputSprocket support. It cuts down on performance
tremendously. I have a G3 466 which cpu benches around 1500 on MacBench
5. With the MacAlly iShock driver installed, my bench was cut down to
around 1200. That's 300 points off, around a 20% decrease. So just
enable the driver when you want to play X-Wing or Tie-Fighter (or
whatever nonInputSprocket game you want to play).
Thank You!
Solution #3
Not Rated (0)
Odud
Rating: 0%, 0 votes
What games will the analog input work with?
Mike.
Thank You!
Solution #4
Not Rated (0)
paulrmc
Rating: 0%, 0 votes
in article , Paul Graber at
wrote on 2/20/00 11:53 PM:
I consider it the best gamepad available.
C-Ya!
Paul Lipps
a.k.a. [osX]RaZor!
Thank You!
Solution #5
Not Rated (0)
man1
Rating: 0%, 0 votes
I recently got one after trying and returning a Gravis Xterminator
gamepad. The iShock does a good job of feeling just like a PSX analog
controller. More importantly to me, it is supported very well by
InputSprockets AND by the MacAlly software allowing you to assign
keystrokes and mouse movement and clicks to all the control elements.
The Xterminator only offered InputSprockets support and in at least one
game, Ferazel's Wand, that support was incomplete.
Den Giblin
Thank You!
Solution #6
Not Rated (0)
Ross
Rating: 0%, 0 votes
Hopefully it will in 1.3
Dan Rudolph
Thank You!
Can you Help with these PC Gaming Devices problems?
PC Gaming Devices
I have just purchased an Acer Aspire PC. I have a a...
PC Gaming Devices
I have Call 2 Duty for my pc. and i can not get it to down...
PC Gaming Devices
I was told that the logitech extreme gaming headset was a...
is there a driver for xp?
is there an xp driver? if so where can i find it.
Loading problems.
Repair Service
Find PC Gaming Device Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
