Question about Toshiba DKT-2020 Corded Phone
Choosing which lines ring.
I have a multiline Toshiba DKT2020-SD. Some phones ring at their station on incoming calls and others don't. How do you change each phone to either ring or not ring per line at each handset?
Thanks for any help.
  • 38 Answers
Izzit the incoming ringging assignment??
what key phone system using??
DK series??CT series? CTX/CIX series?
if CTX/CIX can set diffrent lines from trunk assignment
Posted on Feb 27, 2009
    President:
  • 2,976 Answers
If you have a multi line setup, you have a phone router. Have your phone company come in and program it for you.
Posted on Feb 17, 2009
Toshiba dkt2020 sd
If there is a Dnd butto programmed, it will be located on the top right hand side. By pressing the do not disturb button the ring wil be abbreviated. otherwise it you will have to go into the phone system programming to make that phone not ring.
Oct 01, 2013 | Toshiba DKT-2020 Corded Phone
How do I change the "on hold" music for my Toshiba DK phone?
Locate your main telephone room or closet.
You will see a TOSHIBA ksu.
The music source should be in the same room.
Tony
Ameriel
732.477.7733
Aug 13, 2009 | Toshiba DKT-2020 Corded Phone
Toshiba DKT2010-sd ringing in ear while on a call
1) To stop the ringing in your ear, press Redial and Vol Down at the same time
The following must be performed from station 10 or 200.
2) To change date : Press INTCM, #, 6, 5, 1, Enter date YY/MM/DD, press redial
3) To change time : Press INTCM, #, 6, 5, 2, Enter time HH/MM/SS in 24 Hr Format, press redial
4) To change day of week : Press INTCM, #, 6, 5, 3, Enter day (1=Sun, 2=Mon...), press redial
For more information regarding your Toshiba DKT 2010 Phone and the system that you're using, feel free to browse our extensive guides and manuals that you can find here
Or you can call me at 1-800-903-9190
May 05, 2009 | Toshiba DKT2010SD Phone
Samsung prostar 816 plus system ringing problem
sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
0 = keyset 1=slt set
enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
hope that helps out.
Mar 05, 2009 | Samsung Prostar 816 Phone
Some phones light up but there is no ringing...
is the ringging assignment setting
means downstair phone been set for incoming ring, so u can see the indicator ligh on and ringging
up stair dint assign a incoming ring so that u only can see the indicator light always blinking w/o ring...
contact yr phone provider to set the ringging assignment
Feb 24, 2009 | Toshiba DKT-2020 Corded Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
I am using a toshiba DKT2020-SD. I need the other phones to ring when their is a call to the main line.  I also need to find the manual online. Can someone please help me?
If you have a DK system you can program by any phone with a display. On the larger DK system it must be done on extension 205. I would advise to look at program 81-87 to adjust ringing on system. If you have a CTX phone system you will need emanager software. Below is a website with manuals. Hope this helps.
http://www.wedophones.com/ToshibaManualsLead.htm
Dec 06, 2008 | Toshiba DKT2020SD Phone
Toshiba dkt2020 sd
while the call is on the line, press the greeting button, when you hear the voice press9, then the extension + pound (i.e., greeting, voice, 9, extension, # ) hope this helps.
Jun 05, 2008 | Toshiba DKT-2020 Corded Phone
Toshiba DKT-2020 Corded Phone Logo
442 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
