Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
How to remove bad secters - Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
    Sergeant:
  • 219 Answers
You can always try defragmenting your hard-drive. I recommend that you run the Full/Access method from O&O Defrag. Just use their free 30-day trial.
Posted on Feb 18, 2009
  • 31 Answers
If the bad sectors are software related then you can get rid of them with HDD regenerator:
http://www.tucows.com/preview/300158
If they are mechanical bad sectors then the aforementioned software won't be able to repair them and they will resurface.
Posted on Feb 17, 2009
  • 61 Answers
You can't delete / remove bad sectors, they're faults on your hardware. Once you have a few bad sectors, you can be sure that your disk won't last any longer. My advise is to backup now your important files.
2 Suggested Answers
  • 207 Answers
SOURCE: removing bad secter from hdd
there are vaious ways
if u know how to make it slave hdd make it one by one on any desktop and run a disk defrag and scan along wd the consistancy check it is a time consuming process
ill suggest to format them it will take 20 min/hdd
Posted on May 19, 2008
Dell computer hangs
you have problems with windows, check registry errors, download any portable antivirus and check on viruses
Dec 17, 2013 | EliteGroup K7VMM Motherboard
Computer hangs after startup
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer at least two hour a day.
Hope these tips will help.
COMPUTOR SLOW RUNNING
control panel-add and remove program(check if you got more then one antiwires on the computer, if yes then remove it)
%temp% in run window, delet all temp files from it
(if any pop up comes in while deleting it..just press skip)
remove unwanted program or games or anything which you know but dont use it any more from the computer(add and remove program)
try your connection in windows browser(try www.google.com inside the run window and see if its any faster, if it is then could be you browser, reset would help)
Jan 06, 2013 | Acer Computers & Internet
My curser is stuck in the middle of the screen
change the mouse .If it works same as before after change the the mouse format and install.Again it same as before think your HDD has bad secter.so zero fill by dm
Nov 21, 2010 | Dell Dimension 2400 PC Desktop
My 40gb disk drive show error in system boot process, but after some time available in system bios. i was installed xpsp2 just 2 day ago and today it was corrupted. what i do ? please help me.... Sandeep...
Well i think you have bad secters in the hard drive,
try doing a defragment on the hard drive,
but thats the way a hard drive goes when it has bad sector in it,
see if you can get an other drive for it, ebay
Nov 20, 2010 | Samsung 40 GB ATA133 Hard Drive
Iam using lexar 2gb micro sd card and it is showing some bad sectors how to repair and recover the data in the micro sd card
Hi:
You might try formatting the card. Go to the drive and rigth click on properties and then click on tools, first try error checking the drive, a box should pop up that has two options 1. Automatically fix the system errors and 2. Scan for and attempt to recovery of bad sectors select both boxes then click start. If all goes well and windows is able to repair the device then your data is saved. If not them reformating the device is the only way to restore the device, but data on the device will be lost..
Jun 29, 2010 | Electronics - Others
Leaking pitman arm seal at gear box
most of the good rebuild kits have the diagram in it there is not that much in there secter shaft worm gear + some seals and the parts are
not cheap you may be better off with a good used one with fresh seals
Jan 11, 2010 | 1996 Dodge Ram
Removing bad secter from hdd
May 19, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Lacie hadr drive problem
I am looking for some help with the same problem with a Lacie External Hard Drive, does anyone respond to these posts?
Feb 22, 2008 | LaCie d2 Extreme 250GB External with...
When I turn on starts shows microsoft windows then goess to startup repairs
formattt that hard drive sound like bad secters in hd run xp dish cheak chdisk u know to fix those bad secters on hd froma bug or sumthign best best u have orginal xp cd not recovery dish operting system disk boot into that del partions make new one then formatt it then install xp fresh update it so on ok
Jan 24, 2008 | Computers & Internet
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
291 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
